boost controller?
Old Feb 27, 2005 | 03:13 PM
CRAZYHONDA's Avatar
Default boost controller?
can you use a boost controller on a stock dsm t25. it set at 8psi trying to lower it to 5 or 6 psi
Old Feb 27, 2005 | 03:20 PM
siblues's Avatar
Default Re: boost controller? (CRAZYHONDA)
I dont think the boost controller will lower the boost because once you reach the wastegate spring pressure that is what will finally dictate the low setting.Correct me if I am wrong H-T
Old Feb 27, 2005 | 03:46 PM
drvfast's Avatar
Default Re: boost controller? (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I dont think the boost controller will lower the boost because once you reach the wastegate spring pressure that is what will finally dictate the low setting.Correct me if I am wrong H-T</TD></TR></TABLE>
Yes you are correct.
94turboeg
Aug 13, 2007 12:08 AM
rickturboteg
Aug 28, 2006 05:36 PM
c61lude
Jan 19, 2006 04:34 PM
1RS2NV
Mar 15, 2004 03:18 AM
accordfreak
Dec 25, 2001 12:20 AM
