Boost coming on to quick
Old Dec 26, 2005 | 10:43 AM
model x's Avatar
Default Boost coming on to quick
I've got a b16 with a holset hy35 and when it starts spooling it takes like half a second to go from 5psi to 10psi and melts the tires.
Is there anyway to slow the transition?
I'm running open wastegate dump and I was thinking that running it into the exhaust might help slow the spool a little.
Old Dec 26, 2005 | 10:47 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Boost coming on to quick (model x)
I was reading the other day, and someone had mentioned that he was able to tune out such a harsh transition... But with some turbos, it just happends no matter what you do. 15psi in my car even with the tires @ 14psi just spins em...
Have fun!
Blaze
Old Dec 26, 2005 | 10:52 AM
Bspec18's Avatar
try using a smaller spring and then invest in a progressive boost controller
Old Dec 26, 2005 | 11:00 AM
B00STFREAKS's Avatar
Default Re: Boost coming on to quick (Bspec18)
Welcome to FWD and Power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote">try using a smaller spring and then invest in a progressive boost controller</TD></TR></TABLE>
A Progressive Boost Controller is worth a try
Old Dec 26, 2005 | 11:07 AM
model x's Avatar
Default Re: Boost coming on to quick (B00STFREAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00STFREAK &raquo;</TD></TR><TR><TD CLASS="quote">
A Progressive Boost Controller is worth a try </TD></TR></TABLE>
tell me about it
By progressive boost controller do you mean something like a gear based boost setting? These are expensive aren't they.
Old Dec 26, 2005 | 11:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x &raquo;</TD></TR><TR><TD CLASS="quote">
tell me about it
By progressive boost controller do you mean something like a gear based boost setting? These are expensive aren't they.</TD></TR></TABLE>
Yeah gear based correct.
They are a few hundered dollars.
Or you can just bite the bullet and get a AEM
94turboeg
Aug 13, 2007 12:08 AM
bigdaddyradde
Feb 27, 2006 04:50 AM
B1Boosted
Apr 7, 2004 08:56 PM
1RS2NV
Mar 15, 2004 03:18 AM
