Boost a B16a or B18c1???
Old Oct 1, 2009 | 11:36 AM
  #26
solo227's Avatar
Default Re: Boost a B16a or B18c1???
Originally Posted by DA TeG 90
Keep the b16 head and pick up a LS crank and b18c1 block. Perfect combo as you will have the power from the head, tq from the crank and one of the strongest b series blocks!
thats the biggest waste of time...
Old Oct 2, 2009 | 01:04 PM
  #27
DA TeG 90's Avatar
How so? If he is asking what he should use, why not throw in the LS crank? LS crank you will get the most tq. b16 head is fine as its a type r casting. Granted, he could use the b16 block.
Old Mar 8, 2010 | 05:05 AM
  #28
eg9_fann's Avatar
garret make 54 trim and also 57 trim chargers, would I be better off with a 54 with the same spec A/R ratios in the turbine (0.63) running at a higher PSI to gain around 260-280 bhp and a slightly quicker spool up time?
(but the 54 doesnt have the 360 bearing inside it (not standard anyway)) then theirs also the t60 trim..but i think that will make more power than i really want.
and does any 1 know a good kit that has this charger with it or is it only available separately outsourced?
i have b16a2...stock.will probs be sourcing all the parts separately but just doing my homework at the moment.
Old Mar 8, 2010 | 11:23 AM
  #29
Kyle R's Avatar
https://honda-tech.com/forums/forced-induction-49/spoolinperformance-log-manifolds-tubulars-i-c-piping-1404253/
Old Mar 8, 2010 | 11:43 AM
  #30
_kiid's Avatar
yeaah boost the motor you already got
Old Mar 8, 2010 | 11:51 AM
  #31
Psychoteen101's Avatar
Sell the B16 and buy a B18 LS motor.
Lower compression and more displacement. 2 factors you should look at when it comes to boost. Ofcourse if your gonna build the motor regardless, it doesnt really matter.
Old Mar 8, 2010 | 11:54 AM
  #32
Schister66's Avatar
Man U FTW
1. GSR block and head with LS crank/rods
2. LS Block/crank and GSR head
I dont know why anyone would further complicate this by adding B16 parts to the mix. These are the options i would consider if this were my build. Due to cost savings, i went with the second option. Personally i would have rather gone with the first simply for the ease of no external oil lines for the LS/VTEC conversion
b18a-hatch
Nov 10, 2008 07:50 AM
mister Boxer
Feb 13, 2006 10:41 PM
archmage
Jun 1, 2005 05:24 AM
hybrid88hatch
Jul 10, 2003 03:08 PM
