Boost at 7psi with REV HARD
Old Oct 16, 2002 | 09:38 AM
Mr.DC2TurBo's Avatar
Default Boost at 7psi with REV HARD
Hi, I just bought a Rev hard kit for my 01 LS integra... Here are the conponents:
Rev Hard Cast Iron Manifold
Rev Hard T3/T04B Hybrid Turbo
Turbo efficient to 350hp
Rev Hard Intercooler 28x6.5x3
Tial Wastegate
Dump Tube
Vortec Blow Off Valve
2.25" Aluminzed Mandrel Bent Piping
2.5" Downpipe
Progressive Type Fuel Regulator
High Volume Fuel Pump
Purosil Hoses & Clamps
Steel Braided -3 Oil Line
Oil Return Line
High Pressure Fuel Line
High Pressure Silicon Hose
Neccessary Vacuum Tee's
Neccessary Vacuum Lines
My question is, what do I need to run it at 7psi (that's what my wastegate is set at)and not BLOW my engine??? Can I run stock injectors or can I use prelude injectors (290cc) and that's it??? Also, do I really need the air intake and filter or can I just forget about it? Does it add HP with filter? Need info, Thanks for all your help.
Old Oct 16, 2002 | 09:43 AM
echo999's Avatar
New User
Default Re: Boost at 7psi with REV HARD (01xxTurBoxx01)
3 options:
1) Get an inline pump + FMU (Not too reliable)
2) Get new injectors + AFC (Better)
3) Get new injectors + standalone (Best)
Also, make sure that fuel pump is inline if you want to run that FMU option.
Old Oct 16, 2002 | 09:45 AM
TheIntegraGuy's Avatar
Wow..your first post. Anyways, welcome to this site. The Forced Induction forum is the greatest. Lots of help and knowledgable people here. Seems like you got all the stuff down pretty well. Many people would suggest hondata and I would agree with them. Or you can use a Vortech FMU for now...You can probably pick one up for around $80-$100 used. It'll keep you there if you're not planning on boosting more than 7 but that's impossible. Hehe...As for the filter, use it. It'll prevent damage to the turbo, and it's not much of a difference in performance gain if you dont have one.
Old Oct 16, 2002 | 09:48 AM
DIRep972's Avatar
Smarter than you
Default Re: Boost at 7psi with REV HARD (echo999)
he should already have an FMU and inline pump with the kit.
7psi, FMU w/ inline fuel pump and stock injectors u should be fine. dont turn it up above that or you will need bigger injectors.
Old Oct 16, 2002 | 10:51 AM
sutrusu's Avatar
he has a fuel pump and FMU already!
Old Oct 16, 2002 | 11:57 AM
b18b98's Avatar
Default Re: Boost at 7psi with REV HARD (DIRep972)
aren't you notorious for bumping up the boost to 8.5 - 9 psi?
Old Oct 16, 2002 | 12:46 PM
Thanks guys this really helps. I'm short on money so I want to do the cheapest but also some what safe at the same time. What do you guys recommand about this setup. Walbro fuel pump, 310cc with s-afc and also an adjustable fpr?? The kit comes with a FMU but I'm not sure if I need to recalibrate it. Is all FMU set at 12:1 and can I leave it at that?
Old Oct 16, 2002 | 12:54 PM
wickedxboi's Avatar
12:1 should be fine with stock injectors. just make sure you have a inline pump and not intank
Old Oct 16, 2002 | 01:22 PM
Default Re: Boost at 7psi with REV HARD (wickedxboi)
Is 12:1 good for 310cc or do I need to change it? I have a walbro gss342, is that intank or inline??
Old Oct 16, 2002 | 01:58 PM
justinCO's Avatar
gss342=intank
12:1 with stock injectors
Justin
Old Oct 16, 2002 | 03:08 PM
Default Re: Boost at 7psi with REV HARD (justinCO)
Aright now I'm confused... Does the rev hard kit come with intank or inline? Also, if I go 310cc, what should my FMU setting be??
Old Oct 16, 2002 | 04:06 PM
MikeMAN's Avatar
rev-hard i believe comes with an inline
(anyone else, feel free to correct me )
sleepinEP3's Avatar
if his kit came with a walbro gss342, thats an INTANK.
if youre gonna keep the FMU the kit came with, youll need an INLINE pump and CHECK VALVES
i suggest you sell the FMU, use the INTANK and pick up some DSM 450s and an AFC. youll be fine at 7psi with that and at least its somewhat tunable.
but the AFC will only hold up to 12psi so if you want to build and up the boost later you might as well do it right the first time and get Hondata instead of an AFC.
good luck with your decision
[Modified by sleepinEF2, 1:08 AM 10/17/2002]
Old Oct 16, 2002 | 04:32 PM
Default Re: Boost at 7psi with REV HARD (sleepinEF2)
Thanks again everything... I'm not sure what rev hard kit provides for a fuel pump b/c it hasn't arrived yet. I had a walbro left over b/c I had a jrsc and I thought I could use it from before. For now, the MAX I want to boost is 7psi b/c I really have no funds whatsoever and I cant afford 440 injectors with afc hack, hondata, etc. I just want to use what the rev hard kit has.
So once again, what do you think about this setup:
Prelude (290cc) injectors, Progressive FMU (12:1), Aerospeed APR, inline fuel pump, and NGK cold sparks. Will this keep me SAFE at 7psi?? YES OR NO
Old Oct 16, 2002 | 05:16 PM
sleepinEP3's Avatar
youll be fine with a 12:1 with stock injectors.
Old Oct 16, 2002 | 06:21 PM
DIRep972's Avatar
Smarter than you
Default Re: Boost at 7psi with REV HARD (b18b98)
I wouldnt say notorious. but i ran it at .6bar pretty much daily. i dont reccomend people to do that but hey, they can if they want as long as they know what can happen.
Old Oct 16, 2002 | 08:28 PM
roydogg's Avatar
Hey turbox01 who's installing the kit for you? I know a place that can tune it and have it dynoed for 65$ an hr. And he's alittle past King of Prussia area.
Old Oct 17, 2002 | 07:22 AM
echo999's Avatar
New User
Revhard definitely comes with an inline (mine did)... and if it didn't, don't run
without that inline.
Old Oct 17, 2002 | 01:36 PM
Default Re: Boost at 7psi with REV HARD (roydogg)
Hey Roydogg, what is the shop called and do u have the number? How would they tune my car if I have no afc or hondata, just 7psi with inline pump and fmu??
Also here's another question, will I get the same HP at 7psi if I use 310cc or stock injectors?? Does giving more fuel help me increase my hp??
[Modified by 01xxTurBoxx01, 10:40 PM 10/17/2002]
Old Oct 17, 2002 | 09:33 PM
roydogg's Avatar
You can either go to modified motorsports but their in lancaster or SOSNIN.COM and he only charges 65hr. Let me know if you want to go so that I can get my teg dynoed too. I think it would be best if you ran the 330cc injectors.
RPS turbo clutch
Jan 18, 2005 12:36 AM
Rare BlueSI
Feb 7, 2004 10:07 AM
tegaholic
Oct 24, 2002 09:23 PM
Super Cat
May 3, 2002 09:28 AM
