O2 Simulator Instructions?
A friend of my gave me his O2 simulator because he now has Hondata.
So, Now, I have this little black box...
w/ a red wire, black wire, 1 white/black, 1 white/blue, and 1 white/green.
Does anyone know how to wire this thing up?
He said he got it some Zip - ???
Much appreciated, and if you have something useful, please email it to...
loworbitSI@AOL.com
Thank you.
loworbitSI@AOL.com
Thank you.
Re: O2 Simulator Instructions? (8200RPM)
Check out the http://www.7thgencivic.com and search for the info. I have seen it on there I just can't remember where. Type in oxygen or o2 in the search feild and you should find it.
I found the link, this is what he said:
positive/negative self explanatory
RPM wire goes by blue wire by battery under black rubber boot.
o2 sensor wire goes to o2 sensor, you have to cut it and still use the harness, the sginal wire is black. Make sure you hook the simulator to the harness black wire whre you cut it and not going back to the sensor.
TPS wire, look under hood on opposte end of throttle linkage shaft on throttle body. Look for these 3 wires 1) green/yellow 2) red/black 3)yellow/blue the TPS wire is the 2nd one in the middle the red/black.
It is kind of confusing, but I hope it helps.
