blue smoke coming out of exhaust...
Old 06-07-2004, 07:02 PM
B18 CYA's Avatar
Default blue smoke coming out of exhaust...
well, i put my turbo manifold, wastegate and my turbo on a few days ago. intercooler got mounted today just have to do the piping. anyway, at idle i get blue clouds of smoking coming out of my exhaust and sometimes when i drive. I noticed my wastegate was a little loose so I took it off to retighten it and there was oil around the gasket and where u screw down the wastegate . anyone know what that may be caused by? my wastegate and my exhaust are blowing out blue smoke...
Old 06-07-2004, 07:28 PM
1.8turbolsvtec's Avatar
Default Re: blue smoke coming out of exhaust... (c2nap)
you ring lands are gone rebuild time and how much boost were you running
Old 06-07-2004, 07:32 PM
B18 CYA's Avatar
was never boosted yet...just still installingmy turbo ****... engine was rebuilt about 1000km's ago ... brand new block, pistons, rods, crankshaft, headgasket, timing belt... u think its the ringlands? :/
Old 06-07-2004, 08:06 PM
Bailhatch's Avatar
Default Re: (c2nap)
valve guide seals? maybe sucking oil down under higher vacume
Old 06-07-2004, 08:10 PM
B18 CYA's Avatar
hmm, well i just noticed i forgot the ring that goes under the tial wastegate... thibnk thats y or no?
Old 06-07-2004, 09:57 PM
Stu
New User
Stu's Avatar
That won't matter. Take your finger and run it inside your exhaust tip. Is there wet oil in there?
When I installed my turbo, I had to use a rubber hose for the return line for a couple of days. It kink right in half and my car smoked so bad that I got pulled over for "visable emissions" the very first day. Check your oil return line.
Old 06-08-2004, 12:17 PM
B18 CYA's Avatar
yes there was oil in my exhaust tip... just redid my oil return line...it was hanging kinda lower and then goes a lil up... we'll see if this fixed it...will keep u guys updated
Old 06-09-2004, 02:55 PM
B18 CYA's Avatar
found out the prob...oil return line was too low and the oil i guess was staying in the oil return line? getting that fixed as we speak
187Chor
12-06-2007 02:45 PM
jdm-ray
05-28-2006 05:50 PM
Jradrebel
03-03-2005 10:21 AM
tonesdef
05-23-2003 01:40 PM
Quick Reply: blue smoke coming out of exhaust...
