Blue smoke????
Old Jul 24, 2003 | 08:14 PM
B18C4-T's Avatar
Default Blue smoke????
Tonight I hit it in first, and tapped the rev limiter, and second gear for fun and then I let my car idle for about 20 min or so. When I started it I saw a cloud of blue smoke come out the exhaust and thought maybe it was unburned fuel, then when I hit boost I looked in my rearview mirror and saw a LOT of blue smoke. My friend was behind me and said that my car was smoking . Does anyone have any idea what this might be? my setup is:
B18c4
BS manifold
Drag t3/t4
3" dp
RC 440s
Hondata s200
That is just a rough idea of what I have. Tony1 tuned it for me about 2 weeks ago and we found out my injectors are to small and I have hella boost creep, so he set my rev limit @ 7500rpm and my boost cut @ 15psi. I wasn't hitting 15psi until 8100rpm so I am @ about 10-12 psi right now. Any suggestions would be helpful, thanks.
Old Jul 24, 2003 | 08:20 PM
MiraiZ's Avatar
Default Re: Blue smoke???? (B18C4-T)
10-15psi on stock pistons?????
oh man...I htink you may have shattered your ring lands dude...
Old Jul 24, 2003 | 08:25 PM
B18C4-T's Avatar
Default Re: Blue smoke???? (MiraiZ)
That's what I'm guessing, it runs fine, idles fine, just smokes under boost. I'm sure if Tony1 sees this he'll put his .02 in
When I took it to him for tuning I had 2 degrees total timing retard and my a/f was 14.5, I had drived it like that for a year. He couldn't believe it was still running.
Old Jul 24, 2003 | 08:28 PM
grndcont's Avatar
check your compression, look at the spark plugs, and look at the piston tops, then wight back.
Old Jul 24, 2003 | 08:36 PM
SCD16A6's Avatar
wow 14.5 with boost,way to lean.
Old Jul 25, 2003 | 03:08 AM
B18C4-T's Avatar
Default Re: (SCD16A6)
yeah, Tony1 said all the hondata base maps are very lean. I was in Germany and didn't have anywhere to get it tuned.
Old Jul 25, 2003 | 06:17 PM
B18C4-T's Avatar
Default Re: (grndcont)
I did a compression check, car at operating temp, and distributor disconnected, and all plugs out.
Cyl #1-187
Cyl #2-175
Cyl #3-187
Cyl #4-195
My manual says 270 max and 135 min with a max variation of 28.
Does this sound ok? My vacuum guage still sits steady and moves like normal, and I didn't see any smoke when I started it.
Old Jul 25, 2003 | 06:43 PM
Full-Race Geoff's Avatar
Default Re: (B18C4-T)
for a stock motor, the compression test looks ok. One thing which is unlikely, but possible is that your oil return line is either kinked, melted or fialed somehow, check that, otherwise a leakdown test may help diagnose rings... ive seen shattered rings that functioned well...
Old Jul 25, 2003 | 06:48 PM
B18C4-T's Avatar
Default Re: (FFgeoff)
I put a brand new oil return line in about two months ago. It's steel braided with the high temp internals and an fittings on both ends. It is a perfect fit with no room to bend or kink. I'll have to find somewhere that can do a leak down test. If my engine is ok I'll by buying my full race mani in Sept, if it's not then it will be next spring. Thanks for looking Geoff
Old Jul 25, 2003 | 07:56 PM
MiraiZ's Avatar
does it smolke at all during idle??
Old Jul 25, 2003 | 08:13 PM
boostCreep's Avatar
Default Re: (MiraiZ)
take your filter off your turbo and play with your shaft no really...if it has alot of play oil is probably leaking into it and burning up
Old Jul 25, 2003 | 08:26 PM
B18C4-T's Avatar
No, it doesn't smoke at all during idle. I have noticed a little oil in the intercooler piping, maybe that's it? I just don't understand why it was yesterday and not before or since.
Old Jul 25, 2003 | 08:28 PM
MiraiZ's Avatar
that usually is a sign of blowby...is your breather valve routed back to the intake? If not, it may be your turbo seals
Old Jul 25, 2003 | 08:48 PM
T3T495GSR's Avatar
sorry i dont mean to sound dumb , but what is a b18C4?
Old Jul 26, 2003 | 04:35 AM
B18C4-T's Avatar
Default Re: (T3T495GSR)
It's a B18c that comes in a 5 door civic in Germany. It comes with an LSD and supposedly has a stronger metal content than normal B series. Ask Tony1 or Kenny about it.
Old Jul 26, 2003 | 06:23 AM
T3T495GSR's Avatar
is it equivalant to a b18c1 or b18c5 or just a b18C?
Old Jul 26, 2003 | 06:42 AM
B18C4-T's Avatar
Neither, it's the block that JUN and Spoon get from Honda for their race engines. The head is a GSR head but the block enters a very grey area. Turbo magazine did an interveiw with the owner of Spoon Sports were the c4 was discussed, that's the only place I've ever heard it published about. Tony and Kenny said that my engine should have blown apart long ago with the program that was installed in my s200.
Old Jul 26, 2003 | 07:39 PM
T3T495GSR's Avatar
sounds cool, sorry you arent getting much help yet on this forumn
Old Jul 26, 2003 | 09:17 PM
B18C4-T's Avatar
It's ok, I'm going to have a leakdown test done to make sure everything is ok before I start driving it again. Everything else seems to check out ok, thanks for your help.
sde780
23
Feb 19, 2013 05:02 AM
area522010
Jul 3, 2011 05:39 PM
TURKISHFORCE
May 26, 2011 05:25 AM
Chipped B6
Mar 1, 2009 11:26 PM
Johnny_Rocket
Apr 9, 2005 06:20 AM
