blue box top psi!
Old Jun 23, 2003 | 03:48 PM
blacksi00's Avatar
Default blue box top psi!
i have a b162 stock with greddy 18g, skunk 2 manifold, 310cc, 255 fuel pump,blue box. will the motor handle 7psi with the 255 fuel pump?
any ideas cause i'm getting tire of 5.5psi!!
Old Jun 23, 2003 | 04:44 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: blue box top psi! (blacksi00)
I think the high compression ratio of the b16a2 will let you do about 8~8.5psi before you run risk of popping the head gasket...
I'm running around on a stock fuel system on my little d16y8 w/greddy kit at 9psi all day long...maybe that helps?
Old Jun 23, 2003 | 08:45 PM
mrod006's Avatar
Default Re: blue box top psi! (stackz)
how long have you been running it at 9 psi? i would do that also but only at the track.
Old Jun 24, 2003 | 02:48 AM
stackz's Avatar
Community Builder
Default Re: blue box top psi! (mrod006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrod006 &raquo;</TD></TR><TR><TD CLASS="quote">how long have you been running it at 9 psi? i would do that also but only at the track. </TD></TR></TABLE>
about 5 months now
Old Jun 25, 2003 | 02:10 AM
MikeSi's Avatar
I went 7 lbs on the same setup but instead of the blue box it was with a vafc and tuned.
Old Jun 25, 2003 | 10:44 AM
JOSEPH's Avatar
Default Re: (MikeSi)
im running 8.5 psi on the greddy blue box
Old Jun 25, 2003 | 10:51 AM
DC2NR's Avatar
We have a buddy in our crew, who has a GReddy kit on his 2k Ex, but upgraded turbo, ( GS-R ), and he drives around daily at 10psi with the blue box. He told me that he drives at 10psi, because the blue box was running hella rich, so he up the boost to try an lean it out, he said it worked a little bit. He's got a nice *** car. Posted a personal best of 13.22 at 103 at VIR, on drag radials.
Old Jun 25, 2003 | 10:57 AM
BlueSi2k's Avatar
Default Re: (DC2NR)
I dont think the blue box corrects for timing so if you plan on running that must boost be sure that you have something to retard per lb of boost. Either that or just retard a couple degrees at the distrubutor.
Old Jun 28, 2003 | 10:20 AM
skierGT's Avatar
Default Re: (BlueSi2k)
some say 10+ psi
https://honda-tech.com/zerothread?id=401287
Bimmerman
May 6, 2005 04:30 PM
VinceVTEC
May 21, 2004 09:20 PM
turboD16
Oct 8, 2003 10:46 AM
BDTURBO
Aug 29, 2003 11:37 AM
blacksi00
Jun 28, 2003 03:26 PM
