V-band clamp gasket?
Decided to throw a V-band clamp on my turbo because i snapped a bolt in my turbo, i couldn't get it out and it was leaking bad, now this thing is leaking bad because i don't have a gasket for it. Anyone running a gasket, and if so, where did you buy it?
Re: V-band clamp gasket? (O16581724 5 2 5)
People don't use gaskets, the idea is the flanges are true and will seal well. My downpipe flange was all warped from the welding, so I went and got some 1800* composite gasket material from NAPA. I simply used snips to make all my exhaust gaskets. The material comes in varying thickness and does a great job.
Re: V-band clamp gasket? (Si Shane)
Sounds good, thanks, yeah, mine when i welded got some spatter on the surface, so i had to scrape a bit, guess it made the leaks.
B16Civic93
03-12-2005 09:00 AM
