blown built motors?
how many of you have blown built motors? i am contemplating an engine rebuild right now due to a 50% loss of compression in clyinder #4. i figure while its apart, might as well build it up. i just want to make sure i'm not pissing even more money down that rathole. if i build the motor, i plan on running about 15 psi, street, with a standalone and larger injectors. insterested in your experiences/opinions. thanks.
[Modified by downpipe, 10:04 AM 12/16/2001]
found metal shavings in my oil if that counts as a blown built motor.
Head ported by rpm nyc.
web cam springs and retainers.
stock gsr cams,
aem camgears
manley valves
Eagle rods
Endyn rollerwaves pistons (10-1, flat tops)
Golden Eage sleeves (81.5MM)
720cc RC injectors
Aem fuel rail,
Aeromotive external fuel pump
Accel Dfi Gen 7
Hopign for 11's
[Modified by ekb18c, 6:15 PM 12/16/2001]
[Modified by ekb18c, 6:16 PM 12/16/2001]
stock gsr cams,
aem camgears
manley valves
Eagle rods
720cc RC injectors
Aem fuel rail,
Accel Dfi Gen 7
Hopign for 11's
I've had a built motor for about 1 year or so. Compression check were within spec and so was the leak down (0-5%). I'm a paranoid freak and I check all fluids, lines, hoses everytime I drive to the shop. I do drive the car hard everytime I drive it. **** is gonna rattle loose so just be prepared for that.
the metal shaving in the oil were very small, yet im quite scared about it. So im going to take the motor apart and do a look on whats going on. Possible problems, - piston melted, bearings.
I'lll keep everyone posted
jdmb16turbo
Jan 19, 2009 08:49 PM
RAAZ227
Feb 22, 2002 08:05 AM
