Blowing....FI E/M fuse...
A little update...I found no loose wires in the resistor box wiring....HOWEver...I did notice something...
Injectors 2 and 3 had the wire on the opposite side for the resistor box...hmm..
Like this:
Injectors 1-4 (resistor wire/ecu wire) (ecu wire/resistor wire) (ecu wire/resistor wire) (resistor wire/ecu wire)
Does it make a difference as to what wire goes where on the injector...
Either way..my car ran and ran today...did some burnouts...let momma D boost in it...I duno.
Like this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi »</TD></TR><TR><TD CLASS="quote">doesn't matter... works like a solenoid... doesnt care which is positive and which is ground.</TD></TR></TABLE>
Thanks. The car ran fine today and that was the only thing I did. Oh well...I guess I will wait til it blows the fuse...please please no no no no
This might be a longshot and you may have already fixed it but follow the wiring for the injector resistor box under the intake manifold. Ive had two cars do this before adn it was the yellow/black power feed wires for the injectors rubbing through on the manifold causing the fuse to blow.
Yeah, this is what is wierd. When the fuse pops, I check continuity to IGP1 and IGP2. Only when the fuse pops. The wiring under the manifold is still in the loom, nothing has been touched. It is a 2000 Si engine harness that is cosher.
in my 2000 Si my aem blue that fuse when I loaded up my base(rich tuned) map. I then changed the map and have been fine since. I have no clue why it blew it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">cosher.</TD></TR></TABLE>
Kosher.
Sorry... its the Jew in me...
Kosher.
