blow off valve install
I looked up a search and I couldn't find anything on an install.
where is a good place to look for vacuum for the BOV.
Also I put an R manifold on my b16 and there is a nipple in the back that looks like it went to the map. I put a hose over it with a screw blockin airflow and I was just wondering if boost would cause this to pop off.
You can get the vacuum signal for the BOV from any manifold source. That nipple you blocked off would be perferct. If you want to make sure it doesn't come off, sinch a zip tie on there really tight. A couple weeks back, I thought my EBC was busted and my car was idling weird too. Turns out the line on the back of my manifold that was for my cruise control and also fed my EBC control unit had blown off. So, yeah, boost CAN blow small vac lines off.
