block posting or block guard?
Old Jun 22, 2002 | 03:41 PM
  #26
Ltech's Avatar
Default Re: block posting or block guard? (Hayasa15)
How come I didn't know about this until now . I sent my block out to GE already. Got any pics?
jason phan
Old Jun 22, 2002 | 05:34 PM
  #27
Turbo Laser's Avatar
Default Re: block posting or block guard? (Ltech)
my bad...its Endyne. I do that all the time.
Old Jun 23, 2002 | 07:54 PM
  #28
pbomers's Avatar
Default Re: block posting or block guard? (NOCARLOSER)
ttt
Old Jun 24, 2002 | 07:07 AM
  #29
X2BOARD's Avatar
Default Re: block posting or block guard? (TinyCRX)
Ok, I'll admit it... I haven't done a search or much reading, but I'm VERY interested now. Has this method of sleeve re-enforcement a new thing or have people been doing it for a while ?
Is this method supposed to compare to sleeving or is it a cheaper, less sturdy alternative ? It does sound (for what I've seen so far) like a viable alternative to sleeving ! Is there anyone already running a block posted setup ?
X2
Old Jun 24, 2002 | 07:17 AM
  #30
int3gra's Avatar
Default Re: block posting or block guard? (X2BOARD)
ive done a search on google and havent found anything about block posting. i even asked a 20 year experience porsche rebuilder and he doesnt even know about.
Old Jun 24, 2002 | 07:22 AM
  #31
BROOD's Avatar
X2
Posting is not really a new trend. It is usually empoyed on open deck engine such as our Honda blocks. I have run a few posted D series blocks in my days. It works really well and I would always choose posting over a blockguard. But I would choose sleeveing over posting.
You should not confust the use of posting versus sleeving (ie GE sleeves). Posting supports the stock bores in the points of high loading, this helps control bore shifting. If you need sleeves.....you need sleeves. Posting will can not subsitiute in that case. Sleeving replaces the weaker oem bore assembly with stronger iron sleeves and also has tabs to control bore shifting.
Blockguards
Posting
GE sleeving
[Modified by SLPR, 8:26 AM 6/24/2002]
Old Jun 24, 2002 | 07:36 AM
  #32
int3gra's Avatar
Default Re: block posting or block guard? (SLPR)
can this work on B series? someone post a link where we can read up on this more.
do you actually drill into the cylinder wall?
Old Jun 24, 2002 | 07:52 AM
  #33
int3gra's Avatar
Default Re: block posting or block guard? (int3gra)
found some info from http://www.homemadeturbo.com/ZC.html
The Block has had alot of work done to it. Bored .20 over, The sleeves has been O-ringd, and Endyn Did block support (posting) using Aluminum Studs to support the sleeves under boost conditions, this is what Larry Widmer uses on his 25psi Daily Drivin Civic. These are Alot better then blockguards since they dont take away the cooling from the top of the cylinder.
You Can see in this Pic where the Posting was done at, Their are a totaly of 12 studs. Looks like they sealed it with a epoxy or JB weld.
Old Jun 24, 2002 | 08:29 AM
  #34
Aeka GSR's Avatar
New User
wow, this looks like a good option for us that have acess to a machine shop or someone that can do it for them. Anyone know of a detailed howto?
Old Jun 24, 2002 | 09:12 AM
  #35
Sonny's Avatar
Yes, you drill through the cylinder wall in 12 locations (see my picture above).
I'll have more info later this week. My block is at the machinist getting drilled/tapped as I type this.
The posts are being made by a machinist friend of mine and I hope to have them this week as well. If there is enough interest in this process, I can probably sell sets of posts to make this process easier for anyone else who wants to try it.
Sonny
Old Jun 24, 2002 | 11:05 AM
  #36
pbomers's Avatar
Default Re: block posting or block guard? (Sonny)
sonny-
i would be all about that. can't wait to see pics of the block after it gets back from the shop. kepp us updated. Paul
Old Jun 24, 2002 | 09:07 PM
  #37
pbomers's Avatar
ttt
Old Jun 24, 2002 | 09:13 PM
  #38
Aeka GSR's Avatar
New User
oh boy! keep us updated please!
edit: so how would this translate to a b block? same difference?
[Modified by Aeka GSR, 10:14 PM 6/24/2002]
Old Jun 24, 2002 | 10:04 PM
  #39
AbaZ's Avatar
The pic above is my block, after having the posting pinning support done I took it back to my local machine shop. Even with the studs only torqued to 1inch pound it slightly shifted the sleeve. How much? god I am not a machinest so I dont know, but the guy who did all my work is a true professional and said that Posting/Pinning should be done BEFORE you get your block bored/honed.
The Studs are the exact same alloy as the honda block so it can heat up/contract the same amount.
Supposivly Nascar uses this in alot of their open deck blocks.
So far so good with mine, I have only taking it up to 14psi, still waiting on my custom turbo manifold and 900cc injectors.
Jeff Frank
Old Jun 25, 2002 | 12:58 AM
  #40
eddie1681's Avatar
New User
Default Re: block posting or block guard? (AbaZ)
Please keep us updated
Thanks
Old Jun 25, 2002 | 05:04 AM
  #41
X2BOARD's Avatar
Default Re: block posting or block guard? (b20z)
Can this be done in conjunction with a sleeved block ?
Old Jun 25, 2002 | 10:01 AM
  #42
eddie1681's Avatar
New User
sonny
Can you use bolts made of aluminum?
Do you you think posting a block with stock bottom end will hold 1.0 bar? (B16A)
Thanks
[Modified by b20z, 7:02 PM 6/25/2002]
Old Jun 25, 2002 | 10:18 AM
  #43
cinq's Avatar
$400 to install? Wouldn't eagle block re-sleeving be better for $750. Drilling the holes thru the block is kinda scary.
Old Jun 25, 2002 | 05:39 PM
  #44
pbomers's Avatar
Default Re: block posting or block guard? (cinq)
ttt
Old Jun 25, 2002 | 06:44 PM
  #45
PrecisionH23a's Avatar
no offense to anyone that did that, but i would never drill holes in my block for posts and JB weld it up... That just seems way to rigged for my taste.
Old Jun 25, 2002 | 07:18 PM
  #46
Sonny's Avatar
Default Re: block posting or block guard? (GudeH23a)
Nobody has demanded that you be a test dummy. That's what some of us are here for.
I probably wouldn't try this on a GS-R or Type R block, but my D16A1 was 99 bucks at Pick N Pull.
Sonny
[Modified by Sonny, 4:18 AM 6/26/2002]
Old Jun 25, 2002 | 10:20 PM
  #47
eddie1681's Avatar
New User
anymore updates sonny?
Old Jun 25, 2002 | 10:22 PM
  #48
Sonny's Avatar
Not yet...I hope to have the posts and the machined block by the end of this week. I hope they finish on time, but you know how that goes.
Sonny
Old Jun 26, 2002 | 12:58 AM
  #49
TurBoXBirD16's Avatar
me 2 , i have no clue what "posting" is
explain with LOTS of info please
[Modified by xbird, 3:04 AM 6/26/2002]
Old Jun 26, 2002 | 09:44 AM
  #50
pbomers's Avatar
Default Re: block posting or block guard? (xbird)
ttt
