Block pictures...
Old Nov 12, 2002 | 10:47 PM
bigTom's Avatar
Default Block pictures...
i just recieved this block back today... i cannot release any information on who it is for or whats going in it... i know i havent seen any pictures of the deck plate yet and im sure others have been waiting to see more pictures... i have to say GE impresses me more and more each time i see there products... definately top-notch work which i have not seen beaten with products that far exceed the GE costs
(ps... the reason the block may seem a little dirty is because we requested it not be cleaned... there is an official NY State sticker on the block that cannot be taken off... we were worried it would come off so we decided not to have it cleaned by GE.)
Old Nov 12, 2002 | 10:49 PM
Gmedalion's Avatar
Default Re: Block pictures... (ek9t)
Cant see anything
Old Nov 12, 2002 | 10:53 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Block pictures... (Gmedalion)
Looks good!!!
Old Nov 12, 2002 | 10:54 PM
DLB1994's Avatar
the head will hit the hood in a street car?
Old Nov 13, 2002 | 12:03 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Block pictures... (DLB1994)
wouldn't that change the r/s ratio, then you would need a crank with a bigger stroke because it you just put longer rods in it wouldn't do anything overall except increase deck height. Even then, wouldn't that make the rods more prone to breaking? besides more torque (which is why ls/vtec and b20 vtec guys do what they do) what are the benefits of running this setup?
Old Nov 13, 2002 | 12:07 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Block pictures... (PreIudeSI)
I think you would run a stroker kit from eagle, and I think, the R/S ratio is around 1.75:1. I may also be way off. Im not sure..
art
Old Nov 13, 2002 | 02:15 AM
The sweed's Avatar
Default Re: Block pictures... (Arturbo)
if you run a deckplate on b16 and get a bigger crank AND longer rods you get a bigger engine with the same rod stroke raito as befor. With 84mm bore 95 mm crank and longer rods. you can end up with a 2,2l b16vtec with 1,75 r/s raito. Pot some FI on it an you got a killer.
Old Nov 13, 2002 | 02:35 AM
downpipe's Avatar
VERY nice! i hope i get to see it in person before it goes wherever it's going....
Old Nov 13, 2002 | 05:25 AM
FOrSfEd's Avatar
Default Re: Block pictures... (downpipe)
Looks good to me.
Lee
Old Nov 13, 2002 | 05:32 AM
EP3_05's Avatar
Very very nice. Should be a great setup when it is all said and done.
Old Nov 13, 2002 | 06:02 AM
Tomakit's Avatar
Default Re: Block pictures... (91civic)
Is purdy.
Tom
Old Nov 13, 2002 | 06:33 AM
bigTom's Avatar
Default Re: Block pictures... (Tomakit)
well its a gsr block... i cant wait to put this thing together
Old Nov 13, 2002 | 07:16 AM
HybridKOOP's Avatar
Hood clearence
Old Nov 13, 2002 | 07:44 AM
Tomakit's Avatar
Default Re: Block pictures... (HybridKOOP)
Hood clearence
...would be the least of my worries.
Old Nov 13, 2002 | 07:53 AM
Loco Honkey's Avatar
Niiiice... Explain the sticker thing, though... I'm not familiar with that.
Old Nov 13, 2002 | 08:05 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Block pictures... (House of Boost)
that is sweet.... maybe on the next block i send them i should have that done....hrmmm.. b17 with LS rods and crank........
Old Nov 13, 2002 | 08:18 AM
mos's Avatar
mos
Default Re: Block pictures... (Boosted97Lude)
Are there any issues with the timing belt being too short or anything else?
Old Nov 13, 2002 | 08:25 AM
BoostinDC2's Avatar
Default Re: Block pictures... (mos)
Nice block Vince does good work
Old Nov 13, 2002 | 07:46 PM
Quick 200k Mile Motor's Avatar
Default Re: Block pictures... (BoostinDC2)
And there is the dummy water pump.. Allows you to use OE timing belt!
Hood clearance: not a prob, just run a hood with a mustang type buldge/scoop
just jk, clearance aint that bad for the d-plated motor, but its tight. External wg is the only problem that comes to mind.
oh, and.. downpipe
[Modified by Quick 200k Mile Motor, 11:47 PM 11/13/2002]
Old Nov 13, 2002 | 08:50 PM
MaxBoost's Avatar
New User
Default Re: Block pictures... (Quick 200k Mile Motor)
what crank is it gonna run...
I talked with vince about building me a 2207cc b-series motor that used an 95mm eagle stroker crank. Is this what your using. I assume the bore is less than 85 if your going FI??? What are the plans for the block?
Old Nov 13, 2002 | 09:07 PM
shamoo's Avatar
Will you make something up for me please?
Yeah, I'm in Jersey too. I don't know anyone with those stickers.
Is it like those mattress stickers that say "It is a federal crime to remove this tag." Hehe
Old Nov 13, 2002 | 09:11 PM
FBP Si 2000's Avatar
Default Re: Block pictures... (shamoo)
Old Nov 13, 2002 | 09:22 PM
Sonny's Avatar
Bitchin!
Sonny
Old Nov 13, 2002 | 09:30 PM
rice4life's Avatar
Default Re: Block pictures... (FBP Si 2000)
is that going to be welded on or just bolted down by the head. all the ones i've seen are welded.
Old Nov 13, 2002 | 09:43 PM
sleepercivic's Avatar
Default Re: Block pictures... (rice4life)
that just reinforces my plans to use Golden Eagle on my block
Very Nice pics
TERRY
