block/head surface preparations for hg install.
Old Jun 2, 2006 | 07:14 AM
igo4bmx's Avatar
Default block/head surface preparations for hg install.
Do you guys leave the block deck and head perfectly smooth? I read on older threads that they were roughing it up a bit "to help seal the deck". I don't think that's a good idea.
thoughts?
Old Jun 2, 2006 | 09:37 AM
mike93boost's Avatar
lmao!! where the hell did you hear that?
you want it perfectly smooth.. one little scratch on it and it may not seal. when i get heads resurfaced they pratically polish them. they look like a mirror. thats when it will seal the best.
Old Jun 2, 2006 | 09:38 AM
igo4bmx's Avatar
Default Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">lmao!! where the hell did you hear that?
you want it perfectly smooth.. one little scratch on it and it may not seal.</TD></TR></TABLE>
thats what i thought
Old Sep 23, 2006 | 11:59 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (igo4bmx)
so i how should get the old **** off
Old Sep 24, 2006 | 01:46 AM
TurdBlown Teg's Avatar
1000 grit sand paper is what i used and s polishing pad from my shop
Old Sep 24, 2006 | 04:07 AM
NJIN BUILDR's Avatar
Default Re: block/head surface preparations for hg install. (igo4bmx)
The older style fiber composite gaskets worked better with a little roughness to the finish.The new mls steel gaskets only work with a smooth surface.
Old Sep 24, 2006 | 05:46 AM
LeGeND4LiFe's Avatar
Default Re: block/head surface preparations for hg install. (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The older style fiber composite gaskets worked better with a little roughness to the finish.The new mls steel gaskets only work with a smooth surface.</TD></TR></TABLE>
Whole article about this. http://www.aa1car.com/library/2003/eb30320.htm
Old Sep 24, 2006 | 06:11 AM
HiProfile's Avatar
Default Re: block/head surface preparations for hg install. (LeGeND4LiFe)
This almost makes me laugh when I think how my neighbor had me prep his iron v8 blocks for oval racing - run a big-*** file over it for a while, and blow out the shavings. It worked though!
As what to actually use, I definately wouldn't suggest steel wool, as you don't want any iron particles on that surface. I would also be careful about actually polishing the surface. You don't want to dull any edges, nor do you want to remove much material. You also will want to clean it with alcohol or something afterwards, since a lot of polishes leave sealing residues after being wiped off.
Old Sep 25, 2006 | 05:26 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (kevin716)
so i need 1000 grit for the d15 block
Old Sep 25, 2006 | 08:09 AM
JDM92Bubble's Avatar
bump i would like to know as well
Old Sep 25, 2006 | 09:05 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (JDM92Bubble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM92Bubble &raquo;</TD></TR><TR><TD CLASS="quote">bump i would like to know as well
9seccivicsi
Jan 30, 2005 03:11 PM
Nextelbuddy
Jan 6, 2004 10:08 PM
sshaikh01
Sep 10, 2003 02:19 PM
sporkcrx
Jul 3, 2003 10:44 PM
