block guard question??????
Old Nov 30, 2008 | 06:42 AM
tampabitches's Avatar
Default block guard question??????
ok im going to bulid a mini me and its going to have some where between 13.1 and 13.6 comp. and i want to get it tuned so i can spray a 50 or 75 shot on it and i was wondering if i should use a block guard? its going to be stock bore, and also will a block guard make the motor over heat this will or mite be daily driven car so can someone help me out this is my first build well thanks honda-tech
also does anyone think the high comp on spray is a bad idea???
Old Nov 30, 2008 | 06:49 AM
kyden's Avatar
block guards are useless.
Old Nov 30, 2008 | 10:09 AM
Ls_dx's Avatar
And, Hi compression with spray is a bad idea... without a GOOD tune/ and forged internals...
Old Nov 30, 2008 | 07:31 PM
but what if i got a good tune cuz im going to do a d16a6 bottom end with p29 pistons,arp rod bolts,arp head stups,acl rod bearings,oem main bearing,oem oil pump new,with a y8 head,with a zex cam...and i want to spray on that.
soo what do u think????
Old Nov 30, 2008 | 08:04 PM
IceySC's Avatar
nitrous works good with high compression . i had a 11.7 motor and sprayed a 75 on it.
Old Nov 30, 2008 | 10:15 PM
Mr.Burner's Avatar
and block guards work as long as there installed correctly...
I would use one....ive used them plenty of times with no problems
Old Dec 1, 2008 | 06:42 AM
blakkvtec's Avatar
My block gaurd seems to do me no harm, Use one. BUT>>> Have it installed correctly, then deck the block.
Old Dec 2, 2008 | 06:01 PM
thanks anymore
Old Jan 27, 2009 | 07:57 PM
Christopherian1982's Avatar
Default Re: block guard question??????
What kind of block gaurd is everyone using? Whats a good block gaurd?
vtecb20coupe
Jan 29, 2004 12:23 AM
madhatter07
Aug 13, 2003 08:43 AM
BumpinVTEC
Feb 23, 2003 11:53 AM
philly-O
Sep 15, 2002 05:56 PM
