will a blockguard help my block from nos?
Old Feb 17, 2003 | 12:37 AM
BumpinVTEC's Avatar
Default will a blockguard help my block from nos?
a gu at a local performance shop said that a blockguard will help strengthen my block from nos, i thought they only do good with turbos? can someone clear this up cause im gonna go either turbo or all motor w/ nos pretty soon...im planning on running a 75 to 100 shot on a stock gsr block if i go with that setup, is that to high?
and which is better a tial or delta wastegate and whats the difference? thanks
Old Feb 17, 2003 | 01:46 AM
MiraiZ's Avatar
Default Re: will a blockguard help my block from nos? (jrscLSman)
blockguards aren't good for anything.
Old Feb 17, 2003 | 01:47 AM
LsVTeCTuRBo17's Avatar
A blockguard is to prevent your sleeves from caving or cracking, however usually with a 75 to 100 shot of nos on a stock block blows the ring lances on the pistons, not the block. If you are going turbo make sure to sleeve and block guard if you plan on running more than 12 psi.
Old Feb 17, 2003 | 04:43 AM
Smashback's Avatar
Default Re: will a blockguard help my block from nos? (LsVTeCTuRBo17)
LOL good one.
Old Feb 17, 2003 | 07:38 AM
B20-T's Avatar
Default Re: will a blockguard help my block from nos? (Hatchblack)
woudnt u think the block guard is gonna heat up and cause dentonation or it bring more heat to the motor
Old Feb 17, 2003 | 08:21 AM
Smashback's Avatar
Default Re: will a blockguard help my block from nos? (B20TURB0)
It's an open ended debate that seems to be argued about only by people that have not used a block guard.
But if you use iron sleeves AND a block guard then you're bullet proof
Old Feb 23, 2003 | 10:44 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
i have a block guard on a 100 shot nos and have had no problems but my gsr block is built too and my compression is 11.5.1
Old Feb 23, 2003 | 11:06 AM
B20-T's Avatar
Default Re: will a blockguard help my block from nos? (streetdreams02)
block guard sucks period..overtime it starts to deform your sleeves.
Old Feb 23, 2003 | 11:15 AM
laughinxxx's Avatar
New User
Default Re: will a blockguard help my block from nos? (B20-T)
You can run a 75 shot on a stock B18C as long as you tune it and keep up with the maintenance. You won't have a chance in hell of hooking up on a one stage 100 shot so there isn't much of a point to it.
Old Feb 23, 2003 | 11:18 AM
b18cTurbo's Avatar
Default Re: will a blockguard help my block from nos? (laughinxxx)
you can spray up to 200 shot on stock SLEEVES whithout blockguard
Old Feb 23, 2003 | 11:53 AM
B20-T's Avatar
Default Re: will a blockguard help my block from nos? (C5turbo)
make sure u run cold plugs.
blackccoupe
Oct 14, 2010 10:28 PM
jdong
Aug 4, 2008 08:09 PM
marksturboek
Apr 23, 2006 03:02 PM
menkio
Jun 12, 2004 10:37 AM
