blitz dd bov...anyone else getting compressor surge?
Old Mar 1, 2005 | 07:25 PM
sporkcrx's Avatar
Default blitz dd bov...anyone else getting compressor surge?
Whenever the throttle is released quickly, I get a quick shot of compressor surge. I adjusted the bov as well...only thing I can think of is the vacuum line to it is 2 or 3 feet long...would that cause it? Anyone else have this problem with this bov?
Old Mar 1, 2005 | 07:26 PM
vaporboy12's Avatar
Default Re: blitz dd bov...anyone else getting compressor surge? (sporkcrx)
i dont have a problem with mine 20psi of boost its fine. loosen the spring
Old Mar 1, 2005 | 07:28 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: blitz dd bov...anyone else getting compressor surge? (vaporboy12)
the blitz dd has two spring choices. one for 18psi and below, one for 18psi and above. you might have the stiff spring and thats whats causing the compressor surge. try loosening up the spring some more and see what happens
Old Mar 2, 2005 | 12:32 AM
sporkcrx's Avatar
Default Re: blitz dd bov...anyone else getting compressor surge? (wantboost)
If I loosen the bolt anymore it'll be loose (like hand loose). Are the springs different colors or something? I wonder if I can open it and take a look. I only get it when I shut the throttle quick, and it's only for a second, then you hear the BOV.
Do your guys' sound clean, or do they flutter the first half second?
Old Mar 2, 2005 | 10:55 AM
sporkcrx's Avatar
Also, think the placement of the BOV matters? Mine is right after the turbo.
Old Mar 2, 2005 | 12:10 PM
rmcdaniels's Avatar
My DD had compressor surge when Itried to use it with 20 PSI, I'd hear the compressor chirping a bit before it released the pressure. I think every setup is different. I picked up a HKS SSQV and that got rid of the surge.
Old Mar 3, 2005 | 10:40 AM
sporkcrx's Avatar
Default Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">My DD had compressor surge when Itried to use it with 20 PSI, I'd hear the compressor chirping a bit before it released the pressure. I think every setup is different. I picked up a HKS SSQV and that got rid of the surge.</TD></TR></TABLE>
Yea that's what mine does..but I'm not anywhere near 20lbs. *shrug* maybe I'll just live with it.
Old Mar 3, 2005 | 10:42 AM
sporkcrx's Avatar
Default Re: (sporkcrx)
Anyone wanna do me a huge favor and suck on their DD to see if it holds vacuum
Old Mar 4, 2005 | 11:21 AM
sporkcrx's Avatar
Well today oddly enough it's been working perfectly. Maybe it was just a little stuck/stubborn from sitting for a year or two.
Old Mar 4, 2005 | 12:44 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Anyone wanna do me a huge favor and suck on their DD to see if it holds vacuum </TD></TR></TABLE>
Good to hear it works, and mine never held vacuum.
Old Mar 6, 2005 | 01:21 AM
sporkcrx's Avatar
Good to hear it works, and mine never held vacuum.</TD></TR></TABLE>
ok cool. Unfortunely the compressor surge comes back half the time...imma spray some wd40 or something in there.
Old Mar 10, 2005 | 11:25 PM
sporkcrx's Avatar
Ok, I got it working good now. I took it apart, lubed up the piston and cylinder walls with oil. Put some teflon on the adjusting stud, and tightened it. What I think this did, is move the washer completely below the vacuum port...ever since I moved the spring down more with the adjusting stud, it works awesome!!! So maybe it's not suppossed to be completely loose, but be tightened some. Here's some eye candy.
Old Mar 11, 2005 | 04:34 AM
PM-Performance's Avatar
i was gonna say, mine is pretty damn tight and i still dont get surge. I have no probs with mine.
neoc03
Apr 20, 2009 02:44 PM
ITRICED
Mar 4, 2009 09:33 PM
iNERtIA
Mar 22, 2007 03:24 PM
jep
Oct 12, 2006 05:46 PM
dustin
May 9, 2005 12:12 PM
