Blew the SC61, can I replace w/something similar?
I have a GSR built bottom block tuned with Hondata 4b. My SC61 has completely gone and needs machine work. Would it be ok if I just opted to buy a cheaper, Garret T3/T4 and put it in the SC61's place? What kinda problem will I be looking at? I had an extremely conservative tune (10psi) since I was planning to race later on.
TIA
TIA
Re: Blew the SC61, can I replace w/something similar? (superfuji57)
how long you had it<? u could always send it to precision and see what they say is wrong with it. talk to brian or patrick or i think josh also can't remember
Re: Blew the SC61, can I replace w/something similar? (Muckman)
Contact member B18C1CYA, I think he had that same turbo with little use and lunched it on the dyno...
Re: Blew the SC61, can I replace w/something similar? (infulleffect)
really any turbo should work as long as its got a t3 inlet and a 5-bolt exhaust housing. so if you dont want to have to change anything look for those two characteristics. and if you wanna upgrade than listen to muckman.
btw, which sc61 was it and what mani are you using? (for clearance reasons)
Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Look at the GT30R if you want something smaller. The two bigger GT30s can flow 60lbs/min (600hp) and will spool faster than a SC61.</TD></TR></TABLE> sorry for threadjacking, how is the GT30R compare to a T3T4 as far as size and spool?
Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Look at the GT30R if you want something smaller. The two bigger cartridges can flow 60lbs/min (600hp) and will spool faster than a SC61.</TD></TR></TABLE>
Edit: DOH, Nm. I'm looking for something smaller to spool up faster, but I'm not looking for crazy numbers at the same time. Just fun on the street. Also, not too expensive as in more than what it would cost for a new SC61.
Thanks for the suggestions.
Modified by superfuji57 at 12:07 AM 6/7/2006
Re: (superfuji57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfuji57 »</TD></TR><TR><TD CLASS="quote">
dpetro1, it was an SC61E w/inlinepro mani</TD></TR></TABLE>
im assuming you had it mounted AC style with the compressor on the passenger side? does anyone know if something bigger, say an s-cover will clear like that?
if you are looking to go go smaller how bout an sc34 or sc50 even, still capable of some good numbers, better spool and will drop right in just like the sc61 did.
Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">im assuming you had it mounted AC style with the compressor on the passenger side? does anyone know if something bigger, say an s-cover will clear like that?
if you are looking to go go smaller how bout an sc34 or sc50 even, still capable of some good numbers, better spool and will drop right in just like the sc61 did. </TD></TR></TABLE>
Yeah, that's correct.
I'm looking at those right now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infulleffect »</TD></TR><TR><TD CLASS="quote">Contact member B18C1CYA, I think he had that same turbo with little use and lunched it on the dyno... </TD></TR></TABLE>
yup your right , turned out the turbo was about 2 years old , but I only had about 1k miles on it , and the tech could tell from the turbine wheel so they took care of me for free , there customer service was awsome , had it back in about 2 weeks or so , pte
integraboosted
12-19-2005 12:52 PM
