Big Injectors
Old Apr 22, 2002 | 04:00 PM
B20LS-T's Avatar
New User
Default Big Injectors
First of all my setup is a B16a head with a b18b bottom end sleeved to 84mm. It will be turbo...but not for a while and I am building the motor first then going to piece together the turbo kit. I heard that big injectors will not work without a standalone. I will be getting a hondata but not till I put the turbo on. I will be running 550cc RC injectors and want to put them in when I do the build up so I will have enough fuel for my 2.0L. Is there a way to get it running good with the 550cc injectors and a B&M FPR without a standalone? Let me know what you guys have done/experienced in this type of situation..thanks!
Old Apr 22, 2002 | 04:04 PM
TurboSohc's Avatar
Default Re: Big Injectors (B20LS-T)
You could always you the shity way. Buy yourself a apexi AFC and use the hack. I know they can controll 440's but im not to sure about 550's that might be pushing it. Best bet save your money and buy a hondata stage2b.
Old Apr 22, 2002 | 04:19 PM
B20LS-T's Avatar
New User
Default Re: Big Injectors (TurboSohc)
Well..Im going to get the hondata 4b within a 2 months after the rebuild..but I just dont want to be running such smaller injectors for im afraid it will be running TOO lean and have detonation...but I guess I can just wait the extra two months..thanks! Any other suggestions are appreciated..
Old Apr 22, 2002 | 04:24 PM
sparkz's Avatar
Youll be fine using your old injectors and just bumping up the fuel pressure to around 55psi-60psi.
teg racer 877
Feb 11, 2006 09:10 AM
gsrboy18
Nov 17, 2005 07:55 PM
Turboredteg
Jan 26, 2005 01:17 PM
yisoulja
Nov 30, 2002 10:13 AM
SIK IN DA HED
Mar 8, 2002 12:29 PM
