Big bore throttle bodies
Old Aug 26, 2003 | 03:22 PM
gsr sol's Avatar
Default Big bore throttle bodies
Are there any advantages or disadvantages to running a overbored throttle body on a turbo setup? I am talking about 18psi of boost or so. Can you go too big? There is one site that makes them 70mm. Anyone had any experience with these?
Thanks
Old Aug 26, 2003 | 05:18 PM
Charlie Moua's Avatar
Default Re: Big bore throttle bodies (gsr sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr sol &raquo;</TD></TR><TR><TD CLASS="quote">Are there any advantages or disadvantages to running a overbored throttle body on a turbo setup? I am talking about 18psi of boost or so. Can you go too big? There is one site that makes them 70mm. Anyone had any experience with these?
Thanks</TD></TR></TABLE>
Yeah there is a benifit to it if your COMPLETE turbo setup allows for more flow.... meaning turbo, IM and compression & RPM limits.
Personally IMHO.....for a normal turbo setup 8-15psi stock ITR (62mm to 65mm work great) 70mm would be overkill for most applications. Check out Ericks 70mm TB, or IB 70mm tb. Kingmotorsports can make you a overbore of a ITR (62mm) into a 67-68mm. hTH
importgod21682
21
Dec 28, 2005 09:18 AM
ITRnorway
Jan 9, 2005 06:19 PM
JBk24crx
Jul 22, 2003 04:18 PM
t616
May 25, 2003 07:10 PM
hicamjunkie
May 21, 2003 03:04 AM
