turbo throttle body
Old Jul 22, 2003 | 02:14 PM
JBk24crx's Avatar
Default turbo throttle body
is a 70 or 72 mm throttle body to big for a turbo or will i see big gains in horsepower and torque the bigger the throttle body.
Old Jul 22, 2003 | 04:14 PM
Jared's Avatar
Default Re: turbo throttle body (rub760)
You'll only see gains if the throttle body is a restriction in your setup. I've seen 500whp on a 65mm.
Old Jul 22, 2003 | 04:16 PM
Killer_B's Avatar
i installed the JG manifold with a 70m tb on a stock B16 and lost alot of power and torque. i tried to re-tune with no avail.
i just broke in my built GSR with the JG manifold on it but with a stock B16 TB. i will add the 70mm tb to see if there is a change in the power band. i'll leave it on even if i lose power becuz the car is not dyno tuned yet. i'll let you know the results as soon as i get it tuned.
Old Jul 22, 2003 | 04:18 PM
Boostfed's Avatar
New User
Default Re: turbo throttle body (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">You'll only see gains if the throttle body is a restriction in your setup. I've seen 500whp on a 65mm.</TD></TR></TABLE>
I have seen 500whp with a stock 00 Si B16A TB. ....Mine
406Honda
Jul 6, 2012 05:22 PM
CivSiClone_96
Jun 12, 2008 08:34 AM
BoltonGSR
Dec 7, 2006 12:15 AM
cjames235
Welding / Fabrication
Feb 3, 2005 05:36 PM
StinkyTofu
Apr 21, 2003 08:38 PM
