Best way to control boost???
Old Apr 21, 2002 | 05:18 AM
TurboSi's Avatar
Default Best way to control boost???
I've got a T-25, with the stock internal wastegate, and the stock setting for the wastegate should give me around 8psi boost, but I would like to be able to bring it down to around 5 to start. What is the best way to do this?
Thanks!
Old Apr 21, 2002 | 05:25 AM
MiraiZ's Avatar
Default Re: Best way to control boost??? (TurboSi)
Boost contoller is the best way..or you can try a stronger actuator spring and hunt a peck the settings....
Old Apr 21, 2002 | 05:38 AM
TurboSi's Avatar
Default Re: Best way to control boost??? (MiraiZ)
Would a boost controler be able to lower my boost setting below the stock setting?
Old Apr 21, 2002 | 05:47 AM
MiraiZ's Avatar
yes...it'll help bleed off more exhaust pressure and boost below the spring pre-set
Old Apr 21, 2002 | 06:19 AM
TurboSohc's Avatar
Check out http://www.groupbuycenter.com they are runing specials right now on all greddy stuff and apexi so you could pick up a Apexi Avc-r or a greddy profec A or B. Money is kinda a issue with me so im looking at the greddy profec B but I would pick up the avc-v. Thing is so so nice
Old Apr 22, 2002 | 03:44 PM
TurboSi's Avatar
Could someone tell me how it would do this? I thought that a manual boost controller just adjusted the vaccume/boost signal to the wastegate actuator. How would it make the boost look higher to the actuator, resulting in a lower boost to the manifold? Do they work differently than I thought?
Thanks!
Old Apr 22, 2002 | 04:55 PM
Anubyss's Avatar
Boost controllers can only raise the boost not lower it. Whatever spring you are using is the lowest setting. Tial 35mm usually comes with a 6.5psi spring so unless you change the spring, that is the lowest boost you can run, no matter if you have a boost controller or not.
Am I reading this question wrong? Why would you say that a boost controller can lower the boost below the spring setting?
Old Apr 22, 2002 | 05:25 PM
TurboSi's Avatar
Default Re: (Anubyss)
That is exactly what I thought happened, and I could not see how it would be otherwise, but it was mentioned earlier in this thread that a boost controller could be used.
Thank you for clearing that up, and reassuring me that I"m not an idiot.
Old Apr 22, 2002 | 10:44 PM
turbopimp's Avatar
Default Re: (TurboSi)
Forget the boost controller stuff... T25's typically utilize internal wastegates. Does your T25 have an adjustable actuator rod? If so, then lengthen the rod to lower boost. If your T25 did not come with an adjustable rod, you can cut the rod in half and use a die set to thread both of the cut ends, then use a threaded union to reasemble the rod to whatever length and boost level desired.
Old Apr 23, 2002 | 04:52 AM
TurboSi's Avatar
Default Re: (turbopimp)
I've never heard of doing this, have you done it?
Old Apr 23, 2002 | 05:36 AM
turbopimp's Avatar
I have done this on a Garrett T3 actuator rod as well as a Mitsubishi Td06... and yes it does work. Many aftermarket applications of internally wastegated turbochargers (IHI comes to mind) have adjustable actuator rods.
LSej1
Jun 3, 2008 09:41 AM
br1ev8
Apr 6, 2006 02:44 PM
adseguy
Nov 12, 2005 09:26 AM
GettaluvR
Nov 2, 2002 10:38 AM
FyReo3
Oct 17, 2002 06:50 AM
