Best turbo kit
Old Jun 20, 2013 | 02:38 PM
gitarman2's Avatar
Default Best turbo kit
Im finally looking to put a turbo kit in my 96 b16a2 swapped hatch. Ill start out by saying it is my DD and i'm by no means looking to run some crazy amount of boost. Correct me if im wrong but i've read that if you keep it under 7psi then there is no need to change internals. Also the kit does NOT need to be PS or AC friendly. Finally and most important, budget. Looking to stay under $2000 if possible. Looking for advice from people that actually have a turbo installed.
Old Jun 20, 2013 | 03:18 PM
doood's Avatar
been there done that
Default Re: Best turbo kit
keep saving
Old Jun 20, 2013 | 03:49 PM
aqua_chicken's Avatar
http://www.go-autoworks-store.com/gostkit.html
you would still need an adequate form of engine management as well ie. hondata, chipped ecu w/chrome/Neptune etc
u can also piece together a kit yourself for well under $2k if you know what your looking for.
Last thing, you should not base things off your psi. psi levels are different for each turbo. you should set a whp goal instead.
you wont get advice if you don't do some research on your part
Old Jun 20, 2013 | 07:28 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
OP:
keep searching and reading the FAQ because its apparent that you dont understand that boost/psi/lbs has nothing to do with anything. not trying to be rude but going into the turbo realm isnt always friendly
Old Jun 21, 2013 | 03:58 AM
grumblemarc's Avatar
The Grumpiest
Not happening if you do it right.
Old Jun 21, 2013 | 04:31 AM
89efhatchy's Avatar
X2
Old Jun 21, 2013 | 05:38 AM
BLU CIVIC's Avatar
Track Advocate
sure isn't
Old Jun 21, 2013 | 12:03 PM
gitarman2's Avatar
Well nvm then. Thanks for talking me out of it guys lol. Guess I'm going NA
Old Jun 21, 2013 | 12:08 PM
doood's Avatar
NA is an even bigger money pit. you should probably just leave it stock.
Old Jun 21, 2013 | 12:19 PM
mafia's Avatar
X2. I just got out of the NA game, I'm glad I did. 400 whp feels much better the. 200whp
Old Jun 21, 2013 | 12:53 PM
gitarman2's Avatar
So if im only looking to get around 200-250hp, I can't do that for under $2000?
Old Jun 21, 2013 | 01:13 PM
The Grumpiest
Ebay.
Old Jun 21, 2013 | 02:14 PM
gitarman2's Avatar
...And not destroy my engine
Old Jun 21, 2013 | 03:44 PM
if you want to create power where it doesnt exist, your going to have to spend the money to get there. modding vehicles isnt cheap, you can do i/h/e and think you have massive gains. all real power is made internally, which means you have to spend real money and spend some real time looking to what you want to do
Old Jun 21, 2013 | 04:45 PM
The Grumpiest
Start browsing the Marketplace for deals. You do, however, have to know what it is you're looking for.
Otherwise, nothing.
Old Jun 21, 2013 | 07:48 PM
BLU CIVIC's Avatar
Track Advocate
do it right the first time and avoid a lot of problems. this isn't to discourage you, but you have to know up from that it's an expensive road to take
Jamesc183
10
Nov 26, 2013 11:16 AM
96electronH
Oct 7, 2009 07:53 PM
sspbteg00
Feb 13, 2007 05:00 PM
big-cat
Apr 6, 2006 04:16 PM
