Best PSI level for B20B?
Old May 20, 2004 | 07:21 PM
ek9vboi2's Avatar
Default Best PSI level for B20B?
I have done some research and came up with this... 6-8 is safe. 10 is almost maxing it. Anything over 10 is hell. I want to tune for track, but mostly street. I know the sleeves are very weak, a 84mm bore. What do u think?
Old May 20, 2004 | 07:23 PM
b16ahybrid's Avatar
Default Re: Best PSI level for B20B? (SoHc10Lbs)
sounds good, thanks for sharing.
Old May 20, 2004 | 07:30 PM
D3LSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc10Lbs &raquo;</TD></TR><TR><TD CLASS="quote">came up with this... 6-8 is safe. 10 is almost maxing it. Anything over 10 is hell. </TD></TR></TABLE>
Old May 20, 2004 | 07:45 PM
ek9vboi2's Avatar
lol...no comments eh?
Old May 20, 2004 | 07:48 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Best PSI level for B20B? (D3LSLO)
B20turbohic is running 14-16psi daily with Zdyne.... suck it! (to nobody in general haha ) Its all about the tunning, that is for sure. BTW he laid down about 300whp I believe.
Blaze
Old May 20, 2004 | 08:12 PM
ek9vboi2's Avatar
well yea, its about tuning. im going to use hondata....any good? oh yeah, the infamous MASE is tunning it for me when i ave some time.
Old May 20, 2004 | 08:23 PM
5STAR3's Avatar
Default Re: Best PSI level for B20B? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">B20turbohic is running 14-16psi daily with Zdyne.... suck it! (to nobody in general haha ) Its all about the tunning, that is for sure. BTW he laid down about 300whp I believe.
Blaze</TD></TR></TABLE>
no its more about the thin walls on the sleeves.
Old May 20, 2004 | 08:26 PM
Tony the Tiger's Avatar
No, it's about what turbo you will be running.
PSI is not revelant; when will people learn.
Old May 20, 2004 | 08:33 PM
ek9vboi2's Avatar
t3/t4 from turbonetics. and can u explain ur comment.
Old May 20, 2004 | 08:43 PM
b16ahybrid's Avatar
Default Re: (SoHc10Lbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc10Lbs &raquo;</TD></TR><TR><TD CLASS="quote">t3/t4 from turbonetics. and can u explain ur comment.</TD></TR></TABLE>
Different turbo's make different amounts of power at the same pressure (boost) setting.
A t25 @10psi will make say 200whp while the same set-up and engine with a sc-61 will make 260hp at 10psi. Boost pressure is a measure of resistance.
With a tiny turbo you can run 15psi all day long, but try runnig 15psi on a big turbo your going to stress the motor more because your making a lot more power.
Look at dyo charts of various set-ups. Take a gs-r for instance I see a lot of gs-r's with the average t3t4 making about 260whp with 10psi, I also see a few gs-r's (tuned the same) making 300+ hp @10psi with larger sc-61 turbo's.
big turbo = large flow, large flow = power
small turbo = less flow, less flow = less power
more power = more stress, more stress = more wear, more wear = deminished life of said parts...
In a nutshell........
.i'm going to bed now this proabably makes no sense since I'm doing 10 things at once and typing 90million miles per hour..
Old May 20, 2004 | 09:26 PM
ek9vboi2's Avatar
lol. makes sense 2 me
Old May 20, 2004 | 09:44 PM
5STAR3's Avatar
Default Re: (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">No, it's about what turbo you will be running.
PSI is not revelant; when will people learn.</TD></TR></TABLE>
uh huh.... and show me where i said anything about psi.
Old May 21, 2004 | 04:16 AM
Default Re: (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
uh huh.... and show me where i said anything about psi.</TD></TR></TABLE>
No one was talking to you
Old May 21, 2004 | 11:37 AM
ek9vboi2's Avatar
e-thuggin, here we go again.
Old May 21, 2004 | 11:59 AM
patdemps's Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
.i'm going to bed now this proabably makes no sense since I'm doing 10 things at once and typing 90million miles per hour..</TD></TR></TABLE>
makes perfect sense.
topic of the page says how much boost...well different cars actually put out different power with the same turbo, you could just have a different setup (bigger exhaust, wastegate, intercooler, etc). So, many things can make one car more stronger then the next. You could even have the exact same setup and have different numbers. the question you should be asking is....how much "power" not how much "boost"...you can run 20 psi and be safe on a small *** turbo and turn around and run 20psi on a big turbo and your gonna blow the **** up. Also, tuning is the #1 factor to all of this....make sense?
ekim952522000
10
Aug 25, 2006 08:52 AM
Bambooseven
Dec 22, 2005 02:27 AM
dj4monie
Sep 19, 2005 07:45 AM
nicklk
Sep 11, 2005 08:51 PM
slotec
Aug 30, 2005 09:37 AM
