Best pistons for heavy boost?
rofl... Endyne for me... Wiseco makes em, and they are good... here's mine... All ceramic coated on the top, and plated on the sides like the type r pistons... Yummy.. Can't wait to drive it!
Arias are HEAVY pistons... easily 50 grams apiece heavier than Endyne or Je's... Wiseco/Endyne are the lightest, strongest pistons on the market right now <perfect combination for Imports>
Hey Nathan, go see my parts pics here....
http://home.midsouth.rr.com/jdmcivic/parts
[Modified by SiR Kid, 4:59 PM 10/25/2001]
[Modified by SiR Kid, 5:00 PM 10/25/2001]
My Arias low compression pistons are easily stronger than my friend's low compression JEs I put in his LS/VTEC. Just looking at them, there is more material between the top of the piston and the first ring(can you say detonation protection) and they are much thicker in between the rings. Great pistons.
je all the way... endyn is bs!
art
as for the arias VS. JE deal, I heard that arias pistons are a pain in the **** to drive daily. The piston slap is just horrible...That's what I heard anyways
if you haven't tried them, how can you say this?
sure, you can modify your pistons. But you could just save yourself some hassle and extra expense and just buy them. It's not like Wiseco is a bad piston. Just my thoughts, definately don't want no internet drama.
The arias setups that I've used only make slight noise until the warm up a little, then they are just as quiet as anything else.
j/k
