Best Pistons
Old Aug 3, 2006 | 04:00 PM
harhoosh's Avatar
Default Best Pistons
I looking for 11.5 to 12.0 cr pistons to use it with nitros in my new engine.
what is the best pistons so i can go with?
1. CP
2. Wiseco
3. JE
my spec is:
B20 84mm stock sleeve
eagle H beam rod
Golden eagle guard
p30 head
pw0 cams
JG cam sprocket
JDM pw0 dual valve spring INT & EXH
H22 345cc injectors
DIY ITB's (4agz TB's)
chipped JDM P08
Tunned with crome (By me)
Old Aug 3, 2006 | 04:05 PM
AMR Engineering's Avatar
Default Re: Best Pistons (harhoosh)
To be honest you really can't go wrong with any of those manuf. That is the truth, I have used both JE and CP pistons with great results. Wiseco offers a good piston as well and is used my quite a few engine builders. I believe people will agree with me. It's user preference as well as which manuf. offers what compression ratio and bore as stock shelf.
CP has a piston that will work perfect for you, part#7117 which will drop into a 84mm bore no problem, or if you have a 84.5 you can use part#7118.
I would like to try Wiseco in the future, I like the fact they coat the skirt of the pistons, and they yielded pretty good results from a test that Jeff@Importbuildsers did, but who is to say that test was accurate. None the less, I'd give them a shot. They have a piston made for a b20 with a p30 head.
84mm Part#K567M84
84.5mm Part#K567M845
Old Aug 3, 2006 | 04:17 PM
harhoosh's Avatar
Default Re: Best Pistons (AMR Engineering)
thanks for your usefull replay.
what is the max shot you think i can go with my setup?
i am going to use direct port four fogger.
Old Aug 3, 2006 | 04:40 PM
That's a pretty broad question. It all comes down to your fuel system and just the way your car is setup. Probably need to upgade your pump and a few other things to really push those higher shots. The most I have ran is a 75 shot.
Old Aug 4, 2006 | 04:30 AM
harhoosh's Avatar
any more replay?
Old Aug 4, 2006 | 06:04 AM
HiProfile's Avatar
You can destroy any piston with a shitty tune or an unusual/unforseen issue. You can also make 600whp on any of those w/o issues. I've seen that CP are the most 'perfect' piston (tolerances), but also that they burn their valve releifs if you get oil in the chamber. JE/Wiseco/Arias all seem to have their good & bad stories, but it usually comes down to the fact they are just forged aluminum alloy, which isn't a wonder metal. If I ever have a motor problem, I'd rather the pistons go before the valves, sleeves, bearings, timing belts/gears - so I don't want a wonder metal in there.
Old Aug 4, 2006 | 09:13 AM
alpha's Avatar
I have had experience, either in my own engine or cars I have tuned, with JE, Wiseco, ENDYN, CP, SRP and Ross. All of the pistons withstanded a good amount of abuse. I run CP's in my current engine
Old Aug 4, 2006 | 12:28 PM
quicksilver1689's Avatar
i ♥ snails
anybody run srp's?
Old Aug 4, 2006 | 12:39 PM
Group Tenacity's Avatar
Default Re: (quicksilver1689)
We have had nothing but great success with Arias Pistons.
Old Aug 7, 2006 | 04:57 AM
spoolingb20's Avatar
Default Re: (Group Tenacity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">We have had nothing but great success with Arias Pistons.
Love mine went with Arais after my Valve Reliefs took a shat on me w/ my CP's..... But with all respect when these pistons are failing 9 times out of 10 it isnt the piston that go bad it was some sort of detonation that causes the damage....
Old Aug 7, 2006 | 05:07 AM
DfwBB6's Avatar
CP every builder i talked to recommends so.....id say CP.
Old Aug 7, 2006 | 05:08 AM
non-VTEC's Avatar
JE, Aries, CP, Wiseco
pick one they are all very good pistons.
Old Aug 7, 2006 | 07:30 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">anybody run srp's?</TD></TR></TABLE>
I have for the last 3 years. Great piston for the price.
Old Aug 7, 2006 | 07:54 AM
rudebwoy's Avatar
I've used all three with no problem.
cp is the shiniest
wiseco is well balanced each piston to pin
JE ?
out all I had no problem
Old Aug 7, 2006 | 07:58 AM
RyanEJ8's Avatar
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">
cp is the shiniest
I didn't know how shiny a piston is was a measure of quality now.
Old Aug 7, 2006 | 10:53 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
endyn &gt; * for the simple fact of the time and engineering that goes ito each set for the price.
Old Aug 7, 2006 | 11:28 AM
rudebwoy's Avatar
Default Re: (RyanEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
I didn't know how shiny a piston is was a measure of quality now. </TD></TR></TABLE>
did I say the shininest of it makes it great quality? it was simply mocking people like you. they are all the same materials just different styles. and I noticed a lot of people here love CP, so I figured it was because they are shiney
I used JE in my first build. they were in a package deal
wiseco in my second build. they were cheapest at the time
and Cp in my current. they were on sale
all them went through a lot and never broke
in actuality the best company out there is ARIAS, my next project will have them
Old Aug 7, 2006 | 06:31 PM
Garage 808 Hatch's Avatar
they're probably not the best, but i like the Mahle pistons. and good for a budget. i was running 11.7 in a b16 on a 125 shot. made 281/220 to the wheels. they're quiet, all sets i have seen are incrediblt close tolerences when manu'd. they're under 400 with rings
Old Aug 7, 2006 | 06:54 PM
cuin9sec
Guest
Posts: n/a
CP's
Old Aug 7, 2006 | 07:47 PM
boostedcivicsir's Avatar
Mr. Badwrench
i did in my first b16, i think they should have held up a little better than they did, but it was fun learning. they are a great price as an entry level forged piston also.
my current b16 has JE in it.
my gsr that i am in the process of building right now will be getting CP's. the last 2 engines that i have built for friends have been abused and standing up well on the CP's.
as stated above, all are good. it is all in the tune up.
p.s. i dont know the truth behind this, but was told by my supplier that once a piston is made with a tool from CP, a new tool is used for each new piston, so with that i can see how a shinny piston could be said. he hee.
donvito#1
May 17, 2010 11:19 PM
b18sihatch
Jul 10, 2006 08:35 AM
xDicktonesx
Dec 26, 2005 05:50 AM
BLK99VTECR
Jan 19, 2005 06:40 PM
