best piston/rod combo for b18b
Old Feb 3, 2003 | 09:13 PM
dmotoguy's Avatar
Default best piston/rod combo for b18b
my friend is looking to spend about 700-800, would he be able to run 15-17psi on a b18b? he is currently running 10psi on the stock internals.
what supporting fuel/ignition mods would you suggest, he has stock injectors/fmu/fuel pump/safc
he wants to run about 15-17 psi, what can we do to get him there...
Old Feb 3, 2003 | 09:18 PM
dmotoguy's Avatar
Default Re: best piston/rod combo for b18b (dmotoguy)
he is also getting dsm 440cc injectors
Old Feb 3, 2003 | 09:58 PM
dmotoguy's Avatar
anyone?
Old Feb 4, 2003 | 07:43 PM
dmotoguy's Avatar
Old Feb 4, 2003 | 07:49 PM
boostaholic's Avatar
JE or Wiseco pistons and Eagle rods are a good combo for that price range.
Old Feb 4, 2003 | 07:51 PM
dmotoguy's Avatar
Default Re: best piston/rod combo for b18b (boostaholic)
how much boost can they handle without sleeves? would you suggest a blockgaurd??
Old Feb 4, 2003 | 08:44 PM
boosted hybrid's Avatar
Go with Wiseco's and eagle rods. Dont run a blockguard, they are a waste of money. I had nothing but overheating problem with mine after it was installed, and went through the trouble to make sure it was installed properly.
Old Feb 4, 2003 | 08:59 PM
wickedxboi's Avatar
Default Re: best piston/rod combo for b18b (boosted hybrid)
tuning is key.
Old Feb 5, 2003 | 06:14 PM
dmotoguy's Avatar
Default Re: best piston/rod combo for b18b (wickedxboi)
would he be able to tune it good enough with a SAFC? or does he need to go with hondata?
Old Feb 5, 2003 | 08:05 PM
The vafc will not be able to handle high psi levels. Its nice for anything under 10psi, but personally after using hondata i wouldnt even use it. Go with hondata, and dont look back.
turbolsintegra26
Jan 14, 2015 07:49 AM
riceburnah
Sep 20, 2003 09:01 PM
phatrick2332
Aug 12, 2003 02:36 PM
Sohc Driver
Apr 3, 2003 01:15 PM
InfamousRS
Oct 15, 2001 04:36 PM
