Best head gaskets?
Old Mar 11, 2004 | 07:18 AM
Griffin@Camtech's Avatar
Default Best head gaskets?
what do you guys like for a fairly high boost LS/vtec
I have a oem now should I just go back with oem or is there something better?
Old Mar 11, 2004 | 07:27 AM
copper's Avatar
Default Re: Best head gaskets? (EK2NR)
i would get probably a thicker head gasket unless you have low comp. piston and rods and if you do get the same thickness head gasket but MLS (multi layer steel. Don't get copper. Just get something for turbo app.
Old Mar 11, 2004 | 07:31 AM
yellowturbo's Avatar
OEM is fine IMO ... if you can get some copper ring on the top of your sleeves and your set !
Old Mar 11, 2004 | 07:38 AM
G
sh!t happens.
Default Re: (yellowturbo)
OEM honda
Old Mar 11, 2004 | 07:50 AM
yeah my bad its already 8.8.1 comp
Old Mar 11, 2004 | 07:51 AM
b18bturbo's Avatar
OEM is the way i go. cometic works as well but i like the OEM gaskets better evne for overbored i like the GE gaskets
Old Mar 11, 2004 | 07:55 AM
MikeMAN's Avatar
OEM!!
Old Mar 11, 2004 | 10:25 AM
Charlie Moua's Avatar
Default Re: Best head gaskets? (b18bturbo)
well stock gsr are 10.1cr
I'll be boosting with a smaller turbo that allows me to get full boost of 7psi at like 3000rpm, meaning i'll be seeing a lot more frequencey of boost.
I want to drop it down 1 point.
what head gasket do i need to buy and how much$ cause I don't want to swap out my pistons.
Old Mar 11, 2004 | 10:37 AM
Default Re: Best head gaskets? (Charlie Moua)
DUDE HE STOLE MY THREAD!!!!!!!!!!!!!!! thats wrong!!!
Christopherian1982
Jan 22, 2009 05:38 PM
victoriasamantha
Oct 15, 2008 11:31 AM
invisible
Feb 3, 2007 01:20 PM
teal_deal
May 18, 2005 01:09 PM
D16A6Turbo
Dec 1, 2002 06:16 PM
