Best ecus?
Old Nov 15, 2013 | 06:58 PM
alecrich22's Avatar
Default Best ecus?
trying to decide what the best ecus are for turboing my car. im new to this so can i get some suggestions.
Old Nov 15, 2013 | 08:01 PM
frost_white_ej1's Avatar
first and foremost you fail to even tell what kind of car you have so how can anyone help you out.
Old Nov 16, 2013 | 07:26 AM
Tippyman's Avatar
Default Re: Best ecus?
ECU doesn't really matter so long as it's chippable.
Old Nov 16, 2013 | 10:03 AM
turbohatch96y7's Avatar
Aem v2
Old Nov 16, 2013 | 10:29 AM
wantboost's Avatar
Who is Mr Robot?
MoTEC,ViPEC, Engine Lab, GEMS, Haltech, AEM (copied GEMS and Engine Lab designs for the standard ems and infinity system) and of course, stock honda ecu's
vague thread is vague
Old Nov 16, 2013 | 03:00 PM
1HGEJ2's Avatar
can u sent aem maps how in hondata via data transfer ?...sry 4 my english
Old Nov 17, 2013 | 02:23 PM
wantboost's Avatar
Who is Mr Robot?
sending an aem map to a hondata ecu? won't work... at all. two entirely different softwares
you'd have to manually input the values from the AEM map into the Hondata tables... and you'll have one major issue. The AEM EMS has larger resolution tuning maps (more breakpoints) than the Hondata does, so it wouldn't really work that well in the first place, as you'd have huge gaps in the entered data that the Hondata software would have to interpolate between cells
Old Nov 18, 2013 | 04:02 AM
Freemananana's Avatar
OBD1 ECUs.
Old Dec 3, 2013 | 09:36 AM
alecrich22's Avatar
I guess I just assumed that people would figure it was a Honda. Just looking for some name brands is all.
Old Dec 3, 2013 | 09:45 AM
wantboost's Avatar
Who is Mr Robot?
and we gave you names
the only ecus that are a "plug in" unit would be the AEM EMS, AEM Infinity, chipped obd1 p28/p72, Hondata S300 (uses an obd1 honda ecu)
The rest like MoTec, ViPEC, HALTECH, EngineLab, Megasquirt 3, Megasquirt 3 Pro, Link, etc all require a totally new harness (some come with a flying lead harness that isn't terminated) so you would have to build the harness for each of the above mentioned ECUs to have them work.... They don't use stock ecu plugs.
And if your car is OBD2 then that means you have to remove the custom harness and replace it with the stock ecu so you can pass emissions. You might be able to make an adapter harness to have the custom harness plug up to the stock ecu but you would have to replace every aftermarket/upgraded sensor with stock ones and you would have to splice in the OBD2 data port in order to pass emissions
you need to tell us what you budget is, what kind of "Honda" you're building (make, model, year), what you intend to do with the car, a full modification list, etc before we can even suggest an appropriate Engine Management System
Old Dec 3, 2013 | 10:43 AM
Schister66's Avatar
Man U FTW
That isn't going to help you. Simply knowing the names (without understanding functionality and pros/cons) is completely worthless...
-Hondata s100
-Hondata s200
-Hondata s300
-Neptune RTP
-Crome
-Crome Pro
-AEM
-Haltech
-KPro
-Megasquirt
-Motec
-Uberdata
-etc...
^^See how "useful" that was...
Old Dec 3, 2013 | 12:41 PM
wantboost's Avatar
Who is Mr Robot?
he said he wanted names...
he got names lol
this thread is.. well.. worthless
Old Dec 3, 2013 | 02:17 PM
Schister66's Avatar
Man U FTW
If you want help, we need to know something about the setup...without that, there's no helping you. Purpose, budget, goals, chassis, and other relevant details
Old Dec 3, 2013 | 04:24 PM
1HGEJ2's Avatar
Nope
from aem to aem.
In hondata u can send maps to hondata.
Is that with aem the same?
Old Dec 3, 2013 | 05:23 PM
Yes you can upload maps to a different aem ems. if that's what youre trying to say.
I can send you my map via email you can upload it to your ems and run it.
If its an older version map and you have a newer firmware you just have to convert the cal. its in the tabs on the top of the screen in aem tuner.
chippy
Engine Management and Tuning
21
Dec 4, 2015 03:39 PM
hottopic58
Nov 11, 2009 10:36 AM
brkdwn5
Sep 18, 2005 05:00 PM
NyQuiL
Feb 2, 2004 07:41 PM
.dave
Sep 22, 2003 07:43 PM
