Best cams for turbo
Old Feb 1, 2004 | 11:41 AM
weraider30's Avatar
Default Best cams for turbo
what are the best cams for turbo? they will be going into fully built b16 head and b20 bored to 2.3 block fully built. post some ideas. i have heard skunk 2 is best.
Old Feb 1, 2004 | 12:11 PM
SoulSurfer's Avatar
Default Re: Best cams for turbo (weraider30)
Most people will tell you to stick with the stock cams. Even more people will tell you to search. I just found a post that might help. https://honda-tech.com/zerothread?id=729505
Old Feb 1, 2004 | 12:34 PM
g2turbo's Avatar
Default Re: Best cams for turbo (SoulSurfer)
GSR cams work very well... Better than b16 cams, and type r cams have also been known to make good numbers.... so stock
Old Feb 1, 2004 | 12:44 PM
weraider30's Avatar
Default Re: Best cams for turbo (g2turbo)
but every performance shop i go to say b16 cams are weakest out there and gsr aren't much better. money doesn't matter, i just want the best that can give me the best numbers.
Old Feb 1, 2004 | 12:54 PM
Jared's Avatar
Do a search on it, there are plent of guys making 300, 400, 500, and even 600whp on stock GSR cams.
Old Feb 1, 2004 | 01:06 PM
Adriano's Avatar
Default Re: Best cams for turbo (Jared)
dont you have a b18-non-vtec head? The gsr, type r, or b16 cams wont work.
Old Feb 1, 2004 | 01:17 PM
SoulSurfer's Avatar
Default Re: Best cams for turbo (brryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brryder &raquo;</TD></TR><TR><TD CLASS="quote">dont you have a b18-non-vtec head? The gsr, type r, or b16 cams wont work.</TD></TR></TABLE>
Read the post again.
Old Feb 1, 2004 | 01:18 PM
SoulSurfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weraider30 &raquo;</TD></TR><TR><TD CLASS="quote">but every performance shop i go to say b16 cams are weakest out there and gsr aren't much better. money doesn't matter, i just want the best that can give me the best numbers.</TD></TR></TABLE>
Money always matters. If it doesn't, send me a couple grand.
Don't listen to those shops. Most guys making big power are still using stock cams.
Old Feb 1, 2004 | 01:34 PM
weraider30's Avatar
thanks you guys, but if you have any more info please post
Old Feb 1, 2004 | 02:33 PM
tegedrex's Avatar
Not trying to be a dick, but looking at your setup, why dont you get rid of the fuel manag. and spend the money you would on cams on Hondata or something worth while.
Old Feb 1, 2004 | 03:42 PM
revhigh96's Avatar
I agree with tegedrex. Spend your money on fuel managment. Once you have EVERYTHING else done and you need cams for more power I have heard that toda makes a good turbo cam.
For now I will stick with my stock type R cams. I had a thread along these same lines recently and people actually gained some power putting in GSR cams instead of the type R. Just keep in mind these people were well over 400HP.
Old Feb 1, 2004 | 06:35 PM
weraider30's Avatar
Default Re: Best cams for turbo (tegedrex)
had hondata but had to sell, will have one again soon hopefully, thanks though
Old Feb 3, 2004 | 04:17 PM
weraider30's Avatar
ttt
Old Feb 3, 2004 | 04:21 PM
SoulSurfer's Avatar
Well I know of one nine second CRX running factory cams.
Old Feb 3, 2004 | 04:53 PM
RedTegLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegedrex &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to be a dick, but looking at your setup, why dont you get rid of the fuel manag. and spend the money you would on cams on Hondata or something worth while.</TD></TR></TABLE>
The man makes a good point. I think if you lost that FMU and went back to Hondata you could turn up the boost and tune it and make WAAAAAY more power than any set of cams.
Old Feb 3, 2004 | 05:07 PM
weraider30's Avatar
Default Re: Best cams for turbo (RedTegLS)
dude, if everybody would just read the post then you won't ask questions like this, i am building a new engine, i am no longer doing anything to my ls, i am building a 2.3 b20b w/ b16 head, i will get hondata, but i am not modifying my ls any further, all i am asking is your opinion on cams for that setup
Old Feb 3, 2004 | 05:12 PM
psileepR's Avatar
New User
I havent seen any recent dynos using turbo cams. most go with gsr or itr cams and are making 500+ hp on some nice turbos.
in short i havent seen any solid info that aftermarket cams make more power on turbo hondas than oem.
B16CRXT
Oct 24, 2003 03:16 PM
crexer
Feb 22, 2003 01:12 AM
hondanacura4life
Aug 5, 2002 04:07 PM
EF8SIR
Jan 30, 2002 11:30 PM
