LS cams....
Old Oct 7, 2005 | 09:05 AM
VOLTRONRacing's Avatar
Default LS cams....
aftermarket cams....
running allmotor now and turbo in the spring...
will i need diff. .cams.. or will the all motor cams work with the turbo set up?
Old Oct 7, 2005 | 02:34 PM
notstock93's Avatar
Default Re: LS cams.... (VOLTRONRacing)
Ideally you would want less duration on turbo cams. What all motor cams are we talking here, 404's, 403's? something similar?
Short answer- get smaller cams unless you like a peaky power band
Old Oct 7, 2005 | 03:11 PM
hondaguyef's Avatar
Default Re: LS cams.... (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">Ideally you would want less duration on turbo cams. What all motor cams are we talking here, 404's, 403's? something similar?
Short answer- get smaller cams unless you like a peaky power band</TD></TR></TABLE>
Mostly true but, for some reason boosted honda cylinder heads (especially the B series vtec heads) don't mind making power w/ long duration cams. There's a Couple of dyno graph comparisons on here w/ ITR vs. GSR cams etc. and I've even seen the 402-t's be out powered by 403's in a boosted LS. It all depends and it's sort of a gamble. Cams is the last upgrade on the list for a boosted honda IMO.
Phil
Old Oct 7, 2005 | 03:29 PM
notstock93's Avatar
Default Re: LS cams.... (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
Yea, the bigger cams can outpower the smaller cams, but the tradeoff is in the power band. Plus, VTEC cams are a whole different animal on turbo engines becuase of the smaller primary lobes.
Meh, its up to him. If he wants to have huge power at the cost of drivability, its up to him. Plus, drivability is subjective anyway...
EJ8 GSR-T
Jul 21, 2006 11:02 PM
bigplansnocar
Sep 26, 2003 08:12 AM
russian_racer
Jun 5, 2003 05:59 PM
pkrls
Mar 25, 2003 10:15 PM
