best block for nitrous?
Old Dec 13, 2007 | 08:02 AM
levison's Avatar
Default best block for nitrous?
i am currently running a stock B16 with a built GSR head. i did a conpression check to find out my 4th cylinder is low..175 compression. the rest are 205. if i find out for sure i need a new block whats the best for me to spray a 50 shot on between the B20, B18B, B18c, or B16? thanks for your help.
Modified by levison at 9:54 AM 12/13/2007
Old Dec 13, 2007 | 08:06 AM
DA_HONDA_BOY's Avatar
Default Re: best block for nitrous? (levison)
rebuild the one you got
Old Dec 13, 2007 | 08:15 AM
HiProfile's Avatar
If its going to be a smaller shot, I'd go with a B18B because of the lower compression. The problem is the rods, they won't like as much power as a B16/B18C would, but the CR is getting a bit high with those two.
I'd get a B18A/B since its still cheaper to get set it up for LS/V than to get a good B16/B18C block, and if you blow it afterwards, its 1/3 the price to replace.
Old Dec 13, 2007 | 03:31 PM
EASY101's Avatar
* B A N N E D *
Default Re: best block for nitrous? (HiProfile)
from my experience and understanding...nitrous likes high compression
Old Dec 13, 2007 | 03:34 PM
urbansi's Avatar
Default Re: best block for nitrous? (EASY101)
word
Old Dec 13, 2007 | 03:46 PM
93supercoupe's Avatar
Default Re: best block for nitrous? (urbansi)
i would spray on this motor until u got another one rebuilt
I would personally run a GSR block LS crank if i was NA
Old Dec 13, 2007 | 08:44 PM
quicksilver1689's Avatar
i ♥ snails
find an ls short block for dirt cheap, easy
add your vtec head, easy
spray for the win!
Add some arp rod bolts
Old Dec 13, 2007 | 08:57 PM
CoreyR's Avatar
Default Re: (quicksilver1689)
if you have the money then GSR hands down. but with the comp only being slightly off i would just run it as is until you can rebuilt it.
the higher the compression the better, nitrous doesnt work the same as boost so the lower comp will just make you slower if you go with an LS. not to mention vtec motors are just better all around.
Old Dec 14, 2007 | 09:51 AM
levison's Avatar
ok thanks for the advice guys.
stadanko
Nov 2, 2009 10:44 AM
smoke247
Feb 10, 2009 08:52 PM
wmertz187
Sep 30, 2008 10:47 AM
egeeb16
Mar 2, 2006 07:37 AM
Monochild
May 31, 2005 05:11 PM
