best b block for aebs sleeves and mad boost?
Old Jun 19, 2003 | 07:55 PM
Neukin's Avatar
Default best b block for aebs sleeves and mad boost?
id take it that the b20 is the best to go for because of the 2.0 but any info would be great like 1.6 bored to 2.0 sounds unlikely but id like ideas. thanks
Old Jun 19, 2003 | 07:57 PM
djdxm's Avatar
Default Re: best b block for aebs sleeves and mad boost? (toyosupr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">id take it that the b20 is the best to go for because of the 2.0 but any info would be great like 1.6 bored to 2.0 sounds unlikely but id like ideas. thanks</TD></TR></TABLE>
Any B Series w/ sleeves can be bored the same as a b20. A b16 would be different displacement but, You can take a GSR and put 84mm and have almost the same displacement as a B20. My B20 sleeves cracked and AEBS said they couldnt sleeve it. I guess the cracks in the sleeves ran too far down and they need part of the sleeve to install theres. I went with golden eagles. AEBS suggested getting a B18 for there sleeves as b20's need a little different type of sleeve. Just bore a B18 to 84mm and you have the same displacement as a B20.
jay
Old Jun 19, 2003 | 08:00 PM
Neukin's Avatar
Default Re: best b block for aebs sleeves and mad boost? (djdxm)
good info thanks... well ab16 block is cheap so just staying with that and boreing it is cool then, i didnt think you could go that extreme.
Old Jun 19, 2003 | 08:02 PM
djdxm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">good info thanks... well ab16 block is cheap so just staying with that and boreing it is cool then, i didnt think you could go that extreme.</TD></TR></TABLE>
Well a b16 w/ 84mm bore I believe is around a 1.8L But with a awesome rod/stroke ratio, would be quite a sweet little motor. A 2.0 will get you more power and torque.
Old Jun 20, 2003 | 04:35 AM
Neukin's Avatar
so with the 1.6 what crank and rods would i use to achive teh 2.0 with the 84mm bore. (that bore doesnt affect how much boost it can handle does it, since its such a large bore, thinner walls ?? i dont know) thanks again
Old Jun 20, 2003 | 05:02 AM
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">so with the 1.6 what crank and rods would i use to achive teh 2.0 with the 84mm bore. (that bore doesnt affect how much boost it can handle does it, since its such a large bore, thinner walls ?? i dont know) thanks again</TD></TR></TABLE>
With aftermarket sleeves they can safely be bored to 84mm, in some cases even 85+mm bore, depends on manufacturer. If you went with aebs sleeves they could bore the B16 to 84mm and you could run high boost. Also if you are totally building a block why not go with a custom crank and custom piston/rod ratio. I think thats the best way you would get what you are looking for.
Modified by DC2R714 at 2:20 PM 6/20/2003
Old Jun 20, 2003 | 08:47 AM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djdxm &raquo;</TD></TR><TR><TD CLASS="quote">
jay</TD></TR></TABLE>
FYI for everyone. If this is the case where you cracked a sleeve so bad where you think it's un-sleevable---then think again. The new Darton closed deck design uses different specs then the originals. These new ones are actually beefier on the OD of the sleeve and requires just about all of the stock aluminum water jacket sleeving to be removed for installation. Keep this in mind next time your ready to turn that old cracked block into a planter.......or you could just send it to me for free
Old Jun 20, 2003 | 11:59 AM
Neukin's Avatar
Default Re: best b block for aebs sleeves and mad boost? (93LSivic)
again what rods and crank do i use on a 84mm bored block to get to the or close to the 2.0 id want??
Old Jun 25, 2003 | 11:20 AM
untitled's Avatar
b18a crank and rods. they are the same as b20.
Old Jun 25, 2003 | 02:31 PM
Neukin's Avatar
Default Re: best b block for aebs sleeves and mad boost? (88crx91integra)
i wanted to know what combinations to use to get more displacement... anyone else?
so by using b18a crank and rods in the b16 with a 84mm bore what does that bump the 1.6 up to?
Old Jun 25, 2003 | 02:59 PM
untitled's Avatar
2.0
the b18a and b20 crank and rods are the same. the b20 gets its extra displacment with the larger bore. im not sure if the crank will clear in the b16 block tho. i dont think you can b/c the b16 block is shorter than the b20/b18. the deck heights are taller.
Old Jun 25, 2003 | 03:57 PM
MotorMatrix.com's Avatar
I am a bad person
Well a b16 w/ 84mm bore I believe is around a 1.8L But with a awesome rod/stroke ratio, would be quite a sweet little motor. A 2.0 will get you more power and torque.</TD></TR></TABLE>
If i'm not mistaken a b16 w/ 84mm pistons is a 1.71 liter. anyone know the math for sure??I'm going by my piston build sheets.
blackeg
Aug 9, 2008 03:06 PM
jdmEF8racer
Apr 17, 2006 03:48 PM
PowerSpeed Motorsports
17
Mar 16, 2006 11:04 PM
stockmr2
Mar 9, 2006 12:51 PM
EVOLMTR
May 8, 2003 03:37 PM
