what kind of coolant temps are you guys seeing?
Especially on the turbo cars, going through the traps, steady cruising for long periods of time(more than 1hr), etc.. Just curious how much your temps went up after turbo.
thanks,
Jared
thanks,
Jared
Re: what kind of coolant temps are you guys seeing? (Jared)
Mine is hot!! I need to get a better radiator...I run between 87 to 95 celcius on hot days....
Re: what kind of coolant temps are you guys seeing? (MiraiZ)
95C is about 203F, that isn't really that hot, I've seen guys run hondas at 210 and higher for extended periods of time without any real problems. Anyone else?
Stock operating temp is 75 celcius...even an additional 10 degrees is 85 (which is where i would like to be at) 95 is way hot dude! I will be getting a twin core radiator soon.
my car runs very cool, takes a little while to get heated up but usually stays around 125 sometimes sitting in the heat up to 180 which i think is normal opperation temp. stock gsr radiator
Re: what kind of coolant temps are you guys seeing? (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">mine usually goes to 180-190 unless i am not moving</TD></TR></TABLE>
As long as I'm moving the temperature is about 88 degrees celcius (or 190F) but if I'm stuck in traffic, it climbs to 95c or 203F
civbeater90
07-23-2002 07:39 AM
