Best alterntive to a filter on the compressor
Old Mar 11, 2005 | 07:10 PM
  #26
Archidictus's Avatar
Unceasing Measure
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">My mom's food strainer worked great. http://www.homemadeturbo.com/f...71530
And you go off track once and you mulch your snail with sand. All you need to do, like everybody has said before me, is use two pieces of screen with a piece of terry cloth in between. Any thinner fabric will keep out particles and breathe well. If you can afford it, you can even use Under Armor fabric. Best of both worlds.
I run this combo on my throttle body because my stock intake arm wore a hole in itself.
Old Mar 11, 2005 | 09:26 PM
  #27
beerbongskickass's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">And you go off track once and you mulch your snail with sand.</TD></TR></TABLE>
Thanks for the advise. Next time I decide to take my car to the sand dudes and race a few 4 wheeler's I will remember what you said.
Old Mar 12, 2005 | 06:55 AM
  #28
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advise. Next time I decide to take my car to the sand dudes and race a few 4 wheeler's I will remember what you said.</TD></TR></TABLE>
Oh.... and don't forget that paddles... you'll get better traction
Old Mar 12, 2005 | 09:32 AM
  #29
DRIVENRacing's Avatar
hahahaha i heard they r having a big import even at the shara desert??? whos down?
Old Mar 12, 2005 | 09:37 AM
  #30
DRAGLS's Avatar
Default Re: (adSPEED)
Window screen what material is it made of?
Old Mar 12, 2005 | 09:42 AM
  #31
nfn15037's Avatar
Default Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">if you guys make a bubble out of the mesh it makes more surface area for the turbo to draw air from, not like the mesh has any restrictions anyways </TD></TR></TABLE>
FWIW even a medium mesh with #6 x .O35 wire has only 66% open area.....which means it block off 34% of the inlet area. No thanks, I run a K&N.
Old Mar 12, 2005 | 01:53 PM
  #32
bonestockls's Avatar
Default Re: (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
FWIW even a medium mesh with #6 x .O35 wire has only 66% open area.....which means it block off 34% of the inlet area. No thanks, I run a K&N.</TD></TR></TABLE>
Holy mathematical calculations batman!
Old Mar 12, 2005 | 02:04 PM
  #33
GeeGee's Avatar
Sounds like most people do it for the "sounding cool" factor.
Old Mar 12, 2005 | 03:29 PM
  #34
C M S's Avatar
Default Re: (Krabbypro)
All the money invested, sounds to me it should be a proper filter...
Old Mar 12, 2005 | 03:34 PM
  #35
DragSource's Avatar
Default Re: (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">FWIW even a medium mesh with #6 x .O35 wire has only 66% open area.....which means it block off 34% of the inlet area. No thanks, I run a K&N.</TD></TR></TABLE>
This is a true statement. . . the screen really does block a lot of your surface area.
IMO - go for what works well, not what "sounds cool"
Old Mar 12, 2005 | 03:40 PM
  #36
BoostedCivicSedan's Avatar
I run a K&N on my car all the time... My turbo was far to expensive to risk it... Still sounds "cool" to me.... I will say though, we removed the filter on the dyno and saw a 6hp gain (granted this filter is pretty dirty) so I ended up putting it back on and just turning the boost up a bit
Old Mar 12, 2005 | 04:17 PM
  #37
nfn15037's Avatar
Default Re: (BoostedCivicSedan)
I figure a car that is running sounds a lot cooler than the 'ca-ching' of a cash register after you shatter a compressor wheel due to a little pebble flying in or having the inside of your motor sandblasted with road debris.
Old Mar 12, 2005 | 04:24 PM
  #38
b16hybridsol's Avatar
some people don;t have the room to run a filter
Old Mar 13, 2005 | 10:31 AM
  #39
eK9aT10pSi's Avatar
such a sexy turbo!!!
Old Mar 13, 2005 | 11:42 AM
  #40
stehigs321's Avatar
Default Re: Best alterntive to a filter on the compressor (eK9aT10pSi)
try the mesh from your dryer. you know the mesh that catches the lint. hows that for an idea. Maybe im onto a new thing
Old Mar 13, 2005 | 11:49 AM
  #41
tony1's Avatar
Default Re: Best alterntive to a filter on the compressor (stehigs321)
Man, I don't know how many times this has been brought up. The screen will make LESS power than even a decent filter, i've done it a bunch of times on the dyno. You loose significant surface area with a screen on the turbo like that, not to mention all the **** that your motor injests. Buy a good filter and be done with it. I've made over 650whp with a small k&n filter, your motor and turbo will thank you...
Old Mar 13, 2005 | 12:26 PM
  #42
Maveric's Avatar
Default Re: Best alterntive to a filter on the compressor (tony1)
filter&gt;screen
Old Mar 16, 2005 | 05:48 AM
  #43
Boosted96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">some people don;t have the room to run a filter
Im with him... I decided to get a 4 inch inlet
I ordered slimfans but even then I dunno how the hell im going to get a filter in there...
Old Mar 16, 2005 | 05:53 AM
  #44
legendboy's Avatar
bwahaha classic
Old Mar 17, 2005 | 03:04 AM
  #45
BoOsTiN Dc2's Avatar
Default Re: (legendboy)
does anyone know which filter i can use for a t3/t67 turbo for a integra, cold side facing driver side. If you do can i get the part # also, im in the market for a filter preferrably K&N
jdmcivic2fast
Jun 22, 2011 07:32 PM
hondamn1320
Feb 28, 2008 05:10 AM
boostcraze
Apr 5, 2004 10:21 PM
VTC_CiViC
Apr 24, 2002 09:46 PM
DeeJay
Jan 20, 2002 05:47 PM
