Bent Carillos
Old Feb 12, 2006 | 09:06 PM
earl's Avatar
Default Bent Carillos
These are Carillo A rods I used in a turbo build. The 2 rods on the left bent after 4 dyno pulls and 3 quarter mile passes. When I talked to Carillo, they gave me no love and basically said I was stupid to use them for big power. Yet no where on their site did they say anything but great things about them. They offered to fix them for something like $160 per rod. When I mic'd the beam of the rod, I discovered they were actually thinner than Manley All Motors. They did suggest I try their Super A's when they come out. I will pass on ever buying their products again.
Old Feb 12, 2006 | 09:12 PM
Dunc's Avatar
BCICAN
Default Re: Bent Carillos (earl)
How much power were these rods subjected to?
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">When I talked to Carillo, they gave me no love and basically said I was stupid to use them for big power.</TD></TR></TABLE>
Funny how they would use that as an excuse... I guess we all bought forged internals to make 180HP like factory
Thanks for sharing
Old Feb 12, 2006 | 09:31 PM
Boosted Chemist's Avatar
Default Re: Bent Carillos (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">How much power were these rods subjected to?</TD></TR></TABLE>
i thought these were supose to be better than manleys and pauters too?
Old Feb 12, 2006 | 09:34 PM
mtber's Avatar
Ouch
Old Feb 12, 2006 | 09:50 PM
turbosnatch's Avatar
uh oh, there goes carillos reputation
Old Feb 12, 2006 | 10:04 PM
Drew Peacock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">These are Carillo A rods I used in a turbo build. The 2 rods on the left bent after 4 dyno pulls and 3 quarter mile passes. When I talked to Carillo, they gave me no love and basically said I was stupid to use them for big power. Yet no where on their site did they say anything but great things about them. They offered to fix them for something like $160 per rod. When I mic'd the beam of the rod, I discovered they were actually thinner than Manley All Motors. They did suggest I try their Super A's when they come out. I will pass on ever buying their products again.
</TD></TR></TABLE>Did they do any other damage? Thanks for the heads up, they definitely hurt there sales there.
Old Feb 12, 2006 | 10:30 PM
AB16A2T's Avatar
Hmm... Time to search other options...
Old Feb 12, 2006 | 10:35 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Bent Carillos (AB16A2T)
Why is the rod bent?
Old Feb 12, 2006 | 10:54 PM
program's Avatar
you should have seen the rod that came out (punched a hole through) my 440 big block road runner. Carillo
Old Feb 12, 2006 | 11:43 PM
LSTEG96's Avatar
if i was carillo, i would stop making honda rods, RIGHT now. they are going to have butt loads of these things laying around in a few months.
how much power earl?
Old Feb 12, 2006 | 11:52 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">When I talked to Carillo, they...said I was stupid to use them for big power. </TD></TR></TABLE>
Before the h-t nut-swingers get all bent out of shape, what did Carillo actually say? There's no way a manufacturer of forged rods is going to say their product is not intended for big power.
Unless your power level was something obscene, like 600+ whp...
Old Feb 13, 2006 | 12:00 AM
liam821's Avatar
25 Year Member
How much power was the motor making Earl?
liam
Old Feb 13, 2006 | 12:02 AM
Dunc's Avatar
BCICAN
Default Re: Bent Carillos (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">
Unless your power level was something obscene, like 600+ whp...</TD></TR></TABLE>
600whp, obscene??? haha....I thought that was normal whp nowdays
Old Feb 13, 2006 | 12:12 AM
boostedK20a2's Avatar
i hope that doesnt happen to my k20 rods (h beam)
Old Feb 13, 2006 | 04:32 AM
410-Dragonz's Avatar
do you think you got the all motor rods (light weight) instead of the rods for boosted apps? i think they sent you the wrong rods. this is weird because i was stuck between carillo and manley rods and now i see this..............&lt;shakes head&lt;
I hope things work out for you dude thanks for sharing.
Old Feb 13, 2006 | 04:35 AM
Gravy's Avatar
600whp obscene?? dood eagles handle 600whp and those rods are $300 for the set!
Old Feb 13, 2006 | 04:47 AM
Tooned's Avatar
I made 604whp+ on Eagles. They seen 34psi. I thought carillo was suppost to be one of the top in rod manufacturing? Would also like to know the power level they were seeing.
Old Feb 13, 2006 | 06:12 AM
D@nnY's Avatar
Default Re: (Tooned)
alot of rods like eagles fail at high rpm or from detonation....not neccesarily from a hp level
and all motor rods are meant to be light more then strong....
Old Feb 13, 2006 | 06:16 AM
wade's Avatar
Default Re: (D@nnY)
this is what i have heard also
Old Feb 13, 2006 | 08:25 AM
earl's Avatar
Default Re: Bent Carillos (liam821)
I don't want to give out the power but it was way above the 600 level. After the race, the motor was making noise. We tore it down and everything looked perfect except there was a funny wear pattern on the piston skirts on 2 of the pistons. There were no signs of detonation on the pistons and the bearings looked perfect. That is when we noticed that the rods did not look straight.
I think the Carillos would be fine for an allmotor application. I would rather run Eagles than Carillos in a boosted situation, however. I will take the blame for choosing the Carillos as I fell for the hype without doing enough research. The engine is now living fine with Pauters. I was just extremely disappointed in the lack of customer support and information coming from Carillo. I'm not telling anyone not to run them, just sharing my experience. This happend several months ago and I have held back on posting this until my emotions were under control on the situation. Everyone should make their own choices.
Old Feb 13, 2006 | 08:55 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Don't all the Supra guys run Carillo rods for their high-HP setups?
Old Feb 13, 2006 | 09:01 AM
st00pid's Avatar
Default Re: Bent Carillos (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Don't all the Supra guys run Carillo rods for their high-HP setups? </TD></TR></TABLE>
lol, yep! They think the Pauters are cheap looking and wont handle the power!
Old Feb 13, 2006 | 09:06 AM
93LSivic's Avatar
Way to go ahead and try to wreak another companies image Whats funny, is in the Carrillo catalog it says plain as day that you shouldn't use these in anything more than a mild all motor build. 50hp a hole to be exact. I would blame myself for the poor choice of rod useage.
Old Feb 13, 2006 | 09:14 AM
95GSRTT
Guest
Posts: n/a
Default Re: Bent Carillos (93LSivic)
way to go on always trying to bash earl....like every other thread he has posted in...go find something better to do
