benefits of open downpipe
Old Mar 3, 2004 | 01:11 PM
HXvtec's Avatar
Default benefits of open downpipe
i plan to boost my y5 soon and wanted to know if open downpipe is better then turbo back. i just got some exhaust work done and wanna keep it on. im only gonna be pushing 6lbs. thanx
Old Mar 3, 2004 | 01:20 PM
swlabhot's Avatar
Default Re: benefits of open downpipe (HXvtec)
Powa! At 6lbs you don't need open dp.
twkdCD595's Avatar
yes... with the turbo the lesser exhaust is the better exhaust.
you will make slight bit more power and it is mucho loud turboness exhaust. edit: I do agree about it being not ness. for 6 psi to do this though... unless for the sound.
Old Mar 3, 2004 | 01:24 PM
HXvtec's Avatar
Default Re: benefits of open downpipe (twkdCD595)
what about open wastegate. i have an internal wastegate on mine.
Old Mar 3, 2004 | 01:25 PM
IntegracinGSR's Avatar
Open downpipe will give you better spool times and make more peak hp, however at 6 lbs it wont make that much of a difference, and of course the open downpipe will be alot louder.. you have to pick what is best and most important to you
Old Mar 3, 2004 | 01:27 PM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">what about open wastegate. i have an internal wastegate on mine.</TD></TR></TABLE>
U mean by external wastegate... An open wastegate= no boost Your internal will hold boost just find at 6lbs. Onlky when you start to run serious boost it would be beneficial to be externally gated.
Old Mar 3, 2004 | 01:42 PM
HXvtec's Avatar
Default Re: benefits of open downpipe (swlabhot)
thanx guys u r very helpfull.
Old Mar 3, 2004 | 03:41 PM
Spooled1.6L's Avatar
Your "only 6psi" will become like Only 10psi when you take that downpipe off! I had my boost set at 7psi and it was hitting almost 11psi as soon as I took the dp off good luck though that thing was a monster though. but I couldn't take it
Old Mar 3, 2004 | 03:47 PM
DaX's Avatar
DaX
Loved
Community Favorite
What someone above said...you probably mean external wastegate. Open wastegate refers to not running a dump tube off the wastegate...which isn't bad if you don't mind dumping soot into your nice clean engine bay, and risking melting a radiator hose or something.
Old Mar 3, 2004 | 04:20 PM
Muckman's Avatar
Moderator in Chief
Open DP sounds like your driving a diseal. Its def not as loud as NA open header but I still dont know how any of you guys driving around with open DP get away with it.
Old Mar 3, 2004 | 05:27 PM
blufke's Avatar
Default Re: benefits of open downpipe (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Open DP sounds like your driving a diseal. Its def not as loud as NA open header but I still dont know how any of you guys driving around with open DP get away with it.</TD></TR></TABLE>
living in southern NM, get away with most anything here.
turboorsupercharger
Jul 26, 2008 06:29 AM
4dek
Mar 8, 2008 10:39 PM
hotimportcrx
May 21, 2005 03:10 PM
T--Rex
May 20, 2005 03:29 PM
Scott - 93HB Si
May 16, 2003 04:58 AM
