bearings
Old Aug 2, 2003 | 11:40 PM
tegasaurus's Avatar
Default bearings
I bought a block from an HT member not too long ago and he threw in some misc parts he had laying around that he had for the block also. In a box there were some bearings so i was pretty excited however the brand turned me off (as i havn't heard of them) - TopLine.
He told me that they were a pretty big domestic brand that had some import production parts. he also assured me he used these bearings on plenty of domestics he's built and they came out with no failure.
Maybe im just a noob but have you guys heard of topline? would you trust their bearings within your motor? http://www.protopline.com
-ryan
Old Aug 3, 2003 | 12:20 AM
sporkcrx's Avatar
Default Re: bearings (tegasaurus)
I'm using their rebuild kit in my new motor right now. Same with thumpu. So far so good, that's about all of the input I can give
Old Aug 3, 2003 | 12:40 AM
tegasaurus's Avatar
Default Re: bearings (sporkcrx)
how many miles have you put on your car since the rebuild and what is your driving pattern like? just easy driving or do you mash it or what?
btw nice dyno but that a/f looks nasty for a n/a motor... get that sucker at 14.0 - 14.7 across, isn't that what n/a motors should be at? im use to 12.3:1 - very strong sohc
Old Aug 3, 2003 | 01:41 AM
sporkcrx's Avatar
So far it's about 200. On the first start up, I let it idle for about 20 mins, checked for anything fucked, then changed it's oil (was clean as hell). After that I drove it like a bat out of hell for a couple days, now just normally (half cruising and half bat out of hell ) But yea, I mash the **** out of it. As for the dyno, it was untuned, even though I had a cam gear and fpr...I didn't feel like paying more money , although I do wonder how much I would of made tuned. It was cheap so I couldn't pass it up...soon I'll be back to the good ol 12's for the a/f
But yea, I mainly bought this whole rebuild kit b/c it was cheap, and it was my first honda rebuild. So if I fucked anything up, oh well, at least it wasn't expensive ****. But so far I'm impressed. For my next build (w/ forged internals) I'm thinking of going w/ some acl bearings and oem gaskets......but I'm not sure, this company may have another buyer again
Old Aug 3, 2003 | 11:48 PM
tegasaurus's Avatar
comon... has anyone heard of these things?
stan? geoff? anyone?
-ryan
Old Aug 4, 2003 | 05:02 AM
Mikeyslude's Avatar
plastigauge and go oem for bearings.
Old Aug 5, 2003 | 04:55 PM
tegasaurus's Avatar
Default Re: bearings (Mikeyslude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikeyslude &raquo;</TD></TR><TR><TD CLASS="quote">plastigauge and go oem for bearings.</TD></TR></TABLE>
good suggestion however i just need some opinions on these bearings that i got for free
Old Aug 5, 2003 | 05:24 PM
thid92's Avatar
can I haz?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
good suggestion however i just need some opinions on these bearings that i got for free</TD></TR></TABLE> why risk it when you can by OEM bearings for a 100 bucks
Old Aug 5, 2003 | 08:10 PM
Killer_B's Avatar
Decipher the codes on the block and crank then order OEM bearings. you are taking a chance using aftermarket bearings.
Old Aug 6, 2003 | 04:44 AM
autoraceparts.com's Avatar
They are King Bearings repackaged by Topline. If you look at the back of them you can see the King logo.
Old Aug 6, 2003 | 10:37 AM
sporkcrx's Avatar
Default Re: bearings (autoraceparts.com)
Are king bearings a well known company for bearings?
Old Aug 6, 2003 | 12:45 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Are king bearings a well known company for bearings?</TD></TR></TABLE>
Old Aug 6, 2003 | 03:31 PM
King bearings are very well known and high quality. These bearings have to meet or exceed factory oem standards. I have never seen a King or any other aftermarket bearing fail due to quality. The most important thing is that you run proper clearance within factory specs.
Old Aug 6, 2003 | 08:55 PM
sporkcrx's Avatar
Awesome! thanks for the info!
Old Aug 6, 2003 | 11:52 PM
Darin D.'s Avatar
everyone always says USE FACTORY HONDA ONLY....factory honda bearings do work excellent and i've never had a problem. but i've started to use ACL bearings in a few motors and they've held up great, and these are motors that see 8500+ rpm daily.
If proper clearances are used and the engine is well maintained you shouldn't have to worry about bearing related problems.
Old Aug 7, 2003 | 12:25 AM
lazerus's Avatar
Default Re: bearings (Willis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willis &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 7, 2003 | 02:04 AM
self_made's Avatar
Default Re: (Killer_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killer_B &raquo;</TD></TR><TR><TD CLASS="quote">Decipher the codes on the block and crank then order OEM bearings. you are taking a chance using aftermarket bearings.</TD></TR></TABLE>
how is this done? I know theres numbers/letters on the crank/block, but with those numbers/letters how do I come up with the bearing colors? thanks
Old Aug 7, 2003 | 02:54 AM
tegasaurus's Avatar
Default Re: (VTECNLUDE)
i took the bearings to a machine shop that is finishing up my block and doing anything necessary to it as well as assembling it... they said the bearings were great and they will install them to spec
thanks guys
-ryan
Old Aug 7, 2003 | 06:33 AM
93LSivic's Avatar
Default Re: (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">... they said the bearings were great and they will install them to spec
thanks guys
-ryan</TD></TR></TABLE>
You cant install them to spec... Theres nothing you can do if they dont fall into spec after checked., short of replacing with the proper bearing. Some people may try to shave or alter the bearings, if this is the case then I would take my motor elsewhere.
Ive used ACL, oem, even clevite. Never had any problems with any of them.....except in mine where I took my LS rods to motorcycle like redlines
gmacarize
May 26, 2007 02:30 PM
O RLY
Aug 29, 2005 11:59 AM
Red D Dragon
19
Dec 1, 2004 03:03 PM
made in JAPAN
Jun 11, 2004 08:59 PM
InfamousRS
Feb 13, 2002 07:42 PM
