basemap question
Old Nov 17, 2011 | 10:27 PM
MurtazaDSM's Avatar
Default basemap question
If I have a stock gsr turbo with 450cc injectors and walbro 255 fuel pump with chipped p28 with a basemap will I need a FMU? I just need the base map untill it gets tuned also would I need a missing link? thanks
Old Nov 17, 2011 | 11:03 PM
komat's Avatar
Default Re: basemap question
if you got a turbo basemap on your setup. you wont need a fmu or missing link.
you would want to get the car tuned asap with the basemap. dont go around racing people or doing top speed runs
Old Nov 18, 2011 | 04:27 AM
EsotericImage's Avatar
Retired Moderator
get bigger injectors and a tune!
Old Nov 18, 2011 | 07:15 AM
komat's Avatar
the injectors are fine if the motor is stock
Old Nov 18, 2011 | 07:37 AM
Retired Moderator
FMU and Missing links are old skool technology. no one uses them anymore, But since your boosting, the injectors are on the small side.
Old Nov 18, 2011 | 07:51 AM
SiRCiviC94's Avatar
would someone care to explain the fmu and missing links?
i need a working basemap to get me to a tuner shop. isnt the chip based on the injectors your using?
Old Nov 18, 2011 | 01:54 PM
Retired Moderator
no, the base map is the map for the engine..
meaning if its a blank chip, you add the map for an LS or GSR, or D16, or B16..
basemap is just the OE map for the OE engine. It will get you where you need to go OUT OF BOOST..
the chip is usually blank til the tuner can burn your settings to it. (overwriting the basemap)
Old Nov 18, 2011 | 02:18 PM
jdmadam's Avatar
Wrong.
A basemap is an map burned or loaded to an ecu that is specifically modified for your vehicle & its modifications. A basemap is used for stock or highly modified motors.
Old Nov 23, 2011 | 08:47 AM
MurtazaDSM's Avatar
thanks and the injectors are fine im not trying to do crazy numbers and yup im going to get it tuned just wanted to know if I needed a fmu or missing link if I was gunna use a chipped ecu
Old Nov 23, 2011 | 08:54 AM
Schister66's Avatar
Man U FTW
The basemap you have already accounts for the larger fuel injectors. The larger injectors, in conjunction with a proper basemap, will give the engine the amount of fuel it needs.
In contrast, an FMU is used with stock injectors and uses boost pressure to increase fuel pressure at the FPR. This in turn adds more fuel to the engine. It is a very dumb way of tuning and can be very unreliable since you're pushing stock injectors to 150-200% duty cycle under boost. If one of them hesitates, even for a millisec, the engine is toast.
FMU = F**ks Motors Up
Old Nov 23, 2011 | 09:08 AM
sanman000719's Avatar
thats signature worthy
nokehockey20
May 27, 2016 10:25 PM
superhatchbackbros
Jan 25, 2007 07:33 PM
hotimportcrx
Jul 14, 2005 02:06 PM
egturbo
Oct 6, 2004 02:01 PM
ID_ten_T
Jan 21, 2004 08:54 PM
