banjo bolt?
Old Jun 26, 2004 | 04:40 PM
USDMMARK's Avatar
Default banjo bolt?
man i hate to ask this question, i looked up banjo in search and didnt really answer me so ill ask and hope to not get flamed
what is it, what does it do and can someone post up a pic so i know what im looking for and get a visual, (i learn better that way) thanks
mark
Old Jun 26, 2004 | 04:46 PM
LBR92DA-T's Avatar
Default Re: banjo bolt? (ORIGIN[AL])
Old Jun 26, 2004 | 04:50 PM
USDMMARK's Avatar
Default Re: banjo bolt? (LBR92DA-T)
thanks for the pic, where is that located on a turbo set up and what is it's function?
thanks again
Old Jun 26, 2004 | 05:00 PM
LBR92DA-T's Avatar
it has many uses... the wastegate uses it as a vacuum, the new garrett gt series turbo uses them along with a fitting for the water lines, the supra TT uses it as a oil feed along with the line..
Old Jun 26, 2004 | 05:12 PM
dsadas89das78934's Avatar
your fuel line uses a banjo-type fitting
Old Jun 26, 2004 | 06:08 PM
Cyphear's Avatar
Default Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">your fuel line uses a banjo-type fitting</TD></TR></TABLE>
On the topic, is it important to "index" the banjo bolt so that the fuel flows straight into the fuel line? I always just screw it down and assume that the fuel flows around in those divits in the fuel filter.
Old Jun 26, 2004 | 08:46 PM
Muckman's Avatar
Moderator in Chief
brake lines use em too.
a banjo bolt is just a fitting that is hollow more or less, to form a passage for liquid or air to flow through.
Modified by Muckman at 1:05 AM 6/27/2004
Old Jun 26, 2004 | 11:16 PM
raene's Avatar
Default Re: (Cyphear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyphear &raquo;</TD></TR><TR><TD CLASS="quote">On the topic, is it important to "index" the banjo bolt so that the fuel flows straight into the fuel line? I always just screw it down and assume that the fuel flows around in those divits in the fuel filter.</TD></TR></TABLE>
Not important, look at the inside of the connection from the fuel filter and you'll see that the o-ring type thingie has a groove around the inside for fuel to flow through. Makes no difference.
Old Jun 30, 2004 | 02:15 AM
95gsr's Avatar
Default Re: (raene)
what is the size for the fuel filter to fuel rail banjo not the bolt the banjo it self making custom line.
Thanks
Luis
Old Jun 30, 2004 | 05:41 AM
Cyphear's Avatar
Default Re: (95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsr &raquo;</TD></TR><TR><TD CLASS="quote">what is the size for the fuel filter to fuel rail banjo not the bolt the banjo it self making custom line.
Thanks
Luis</TD></TR></TABLE>
Sorry man, i tried about 10x to read your terrible sentence, and it still doesn't make sense. I cant even guess what you are asking about.
Old Jun 30, 2004 | 06:20 AM
Mad Cow's Avatar
Default Re: (95gsr)
its not one sentence asking more than one thing trying to make custom line
Old Jun 30, 2004 | 07:41 AM
raene's Avatar
Default Re: (95gsr)
https://honda-tech.com/zerothread?id=130634
Old Jul 1, 2004 | 08:32 AM
Cyphear's Avatar
Default Re: (Mad Cow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Cow &raquo;</TD></TR><TR><TD CLASS="quote">its not one sentence asking more than one thing trying to make custom line
For a second thought serious not realize you make custom line too.
nightime25
Mar 16, 2009 10:31 AM
95greenlude
Apr 2, 2007 06:40 AM
kay_animation
11
Jun 17, 2005 04:26 PM
civickiller
Mar 27, 2004 06:43 PM
SupaTeg
Aug 3, 2003 03:15 PM
