bad to run octane booster all the time??
Old Jul 7, 2004 | 06:55 PM
ATS*Mark's Avatar
OG triple OG
Default bad to run octane booster all the time??
just wondering if it was bad to put a bottle of octane booster everytime i filled up . will it hurt the motor?
Old Jul 7, 2004 | 07:03 PM
Drew Peacock's Avatar
Default Re: bad to run octane booster all the time?? (Hella_JDM)
Buy 20 litres litres of a 100low lead, put in 5 litres with each tank full it works much better. Also the slight amount of lead in it good for your valves, you should not have any problems with your o2 sensor not for a long time anyway.
Old Jul 7, 2004 | 07:15 PM
ATS*Mark's Avatar
OG triple OG
Default Re: bad to run octane booster all the time?? (turbozxi)
100LL as in avgas>?
Old Jul 7, 2004 | 07:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">100LL as in avgas&gt;?</TD></TR></TABLE>Yes it called that as well, you don't want to use the avgas with a lot of lead in it, 100ll has only 0.58 grams of lead per litre. Its aleast 100oct often as high as 110...
Old Jul 7, 2004 | 07:27 PM
ATS*Mark's Avatar
OG triple OG
are you a pilot too? im just wondering how you knew about 100LL
Old Jul 7, 2004 | 07:31 PM
I use it often, I run 15.5psi on my stock sohc I did some research along time ago when I couldn't boost past a certain level without detonating. Cleared that problem up, I later reliased it was most likely a tuning issue.
Old Jul 7, 2004 | 07:34 PM
ATS*Mark's Avatar
OG triple OG
cool
Old Jul 7, 2004 | 08:50 PM
Danger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">are you a pilot too? im just wondering how you knew about 100LL</TD></TR></TABLE>
are you a pilot ?
Old Jul 7, 2004 | 09:07 PM
ATS*Mark's Avatar
OG triple OG
Default Re: bad to run octane booster all the time?? (JonnyDanger)
yes sir
Old Jul 7, 2004 | 09:35 PM
Danger's Avatar
holy moly ! what kind of planes do you fly ?
Old Jul 7, 2004 | 09:37 PM
ATS*Mark's Avatar
OG triple OG
"air"planes
ahah naw
i can fly whatever the **** i want cause im a baller
but i fly your typical cessnas and pipers
Old Jul 7, 2004 | 09:48 PM
honda9369's Avatar
i would like to know too
Old Jul 7, 2004 | 11:06 PM
leadfoot78's Avatar
Default Re: bad to run octane booster all the time?? (honda9369)
It could play a number on your cat converter and possibly the o2 sensor. My cat did take a **** after about 3-4 months of constant octane booster use, but I don't know for sure that it was because of the octane booster, it's just the most likely reason.
Old Jul 7, 2004 | 11:24 PM
Default Re: bad to run octane booster all the time?? (leadfoot78)
Injectors may foul though some OB's claim to have additives to clean them... That and your plugs. Seriously for the money 100ll is tens times more effective and it costs 10 times less. Will OB hurt your motor no.
Old Jul 8, 2004 | 04:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
Where can you buy 100LL?
swapedhatch
Jul 28, 2005 08:20 AM
CivicEJ1
Dec 16, 2004 09:05 PM
theslugbug
Jul 4, 2004 09:48 PM
0ptimus prime
13
May 19, 2004 09:06 PM
metal-x
Aug 30, 2002 02:40 PM
