bad main can cause fuel pump issues?
Old Oct 26, 2013 | 03:39 PM
carlos8's Avatar
Default bad main can cause fuel pump issues?
I recently installed a new walbro, This days it's start to sound different like tired. I remove the main relay and following the FAQ's discovered a few terminals with to little solder amount. This can cause the pump to act like this?
thanks
carlos
Old Oct 26, 2013 | 04:29 PM
jdmh22eg2's Avatar
Default Re: bad main can cause fuel pump issues?
very very possible. if relay is not commanding correct voltage and or amperage it will put a srain on pump motor and can change pitch of motor
Old Oct 26, 2013 | 05:16 PM
carlos8's Avatar
Thanks, that's what I thought.
I'm not to skill soldering boards, so I gonna buy a new one.
thanks
carlos
Old Oct 26, 2013 | 05:21 PM
Turbo-LS's Avatar
The walbro should be wired with 10awg wire and the stock power wire triggering a 30amp relay
Old Oct 26, 2013 | 05:28 PM
carlos8's Avatar
Yes, I have all the materials for do that, I been lazy.
But I bought 12 awg wire. This will work?
Old Oct 26, 2013 | 05:42 PM
jdmh22eg2's Avatar
ls i have NEVER wired a real walbro 255. not saying it should not be but i have run in last 10 hondas and currently never an issue graphed EVERY one within 6 months and still pullin oem specs for electrics.
btw OP. dont buy new unless they are dirt cheap. go to pick a part get hand full of them for around 10$
Old Oct 26, 2013 | 05:52 PM
Turbo-LS's Avatar
Depends how hard your pushing the pump. 12 will work but 10 is better if pressures will be high on the fuel system.
Old Oct 26, 2013 | 06:02 PM
jdmh22eg2's Avatar
^ tru actual psi used makes 1000x important higher you go more amp capacity. i havenever had to set over base of 51-52psi
Old Oct 26, 2013 | 06:33 PM
carlos8's Avatar
actually I'm at 52psi.
The original wiring at 393whp @18psi it's working fine. But hearing all the guys here mention the 30amp rewire. I think why not for peace of mind.
I think to stick with 12ga wire for now, I'm not planning to go any further in this set up. My turbo is in his peak power.
Old Oct 26, 2013 | 06:40 PM
jdmh22eg2's Avatar
yea i think i was near my comfortable limit of oem wiring on my one setup that was in the low 50's. never hurts to over wire ( to some degree)
Old Oct 26, 2013 | 06:45 PM
Turbo-LS's Avatar
That's not over wiring. The amp requires a 30amp circuit which is 10awg wiring. The stock wiring is inadequate. Yes you can use it but your harming the pump by not supplying the correct amount of amperage due to the tiny stock wiring.
To each his own. IMO do it right the first time.
Old Oct 26, 2013 | 10:54 PM
wantboost's Avatar
Who is Mr Robot?
I always hardwire my walbros with 10awg and a 30amp relay... Easier to do it right the first time and not have an issue then to have to go back and re-wire the pump when you start having issues with the stock wiring.
Did it on my s13 (sr20) and it made a huge difference
Old Oct 27, 2013 | 05:24 PM
carlos8's Avatar
Turbo-LS, it's fine to put the new ground to the rear seatbelt bolt?
Or you recommend other place?
Old Oct 27, 2013 | 06:25 PM
Turbo-LS's Avatar
I had both my 255 and then my 450 grounded to the seatbelt bolt with no issues. The shorter the ground wire the better when talking electrical in a car. My new Magnafuekl mp4303 is grounded to a bracket on the underside of the car about 6 inches form the pump. Its saved me using a self tapper and it allows a good ground.
Old Oct 27, 2013 | 06:34 PM
carlos8's Avatar
thanks man, very helpful.
And also thanks to the others for the help and tips.
Old Oct 31, 2013 | 12:29 PM
carlos8's Avatar
hi guys, Already replace the main and rewire the pump, works super but have two questions:
1-The Fuel pump relay is getting hot. Normal or faulty ground?
2-The fuel pressure don't drop from 60psi no matter how much turns I give to the regulator. It raise but not down, before it was a 52-53psi.
Psychoteen101
Sep 3, 2013 09:18 AM
steveharrmr23
Oct 12, 2009 09:53 AM
crxfreak1117
Aug 15, 2009 06:09 AM
boosteddohczc
10
Jun 11, 2009 09:57 PM
ludelvr
May 27, 2002 03:56 PM
