Bad ? Eagle rods...
Old Mar 25, 2005 | 10:35 AM
  #26
adictionbass's Avatar
Default Re: (nfn15037)
jw if its normal for the honda bearing to be off center when using an eagle rod...
Old Mar 25, 2005 | 10:48 AM
  #27
Default Re: (adictionbass)
i have a honda and an acl bearing here. The honda bearing is wider than the acl, but only on one side.
Old Mar 25, 2005 | 10:57 AM
  #28
Called Eagle, got some pretty interesing info. They said that Gsr rod bearings are skinnier than all other b series motors. The R, b16, ls, ect have wider rods and therefore wider bearings. The Gsr is the only usdm motor with the skinner bearing. I believe he said the civic type R in japan uses the smaller bearings also.
Old Mar 25, 2005 | 11:05 AM
  #29
LSVtechnologytur...'s Avatar
I would say use the honda bearings that match the crank, thats what i did ( Ls crank = ls # 3 rod bearing) .. I platiguaged them and they are all in spec.
Old Mar 25, 2005 | 12:23 PM
  #30
Default Re: (vtec'n)
yea, i went through and ordered all the honda/acura bearings. Just thought some people might be interested in the rod bearing differences. Im sure alot of people know, but i know alot of people dont
Old Mar 25, 2005 | 02:26 PM
  #31
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">Called Eagle, got some pretty interesing info. They said that Gsr rod bearings are skinnier than all other b series motors. The R, b16, ls, ect have wider rods and therefore wider bearings. The Gsr is the only usdm motor with the skinner bearing. I believe he said the civic type R in japan uses the smaller bearings also.</TD></TR></TABLE>
They are wrong, ITR/GSR/B16 use the same sized bearings. LS/B20 is what has a wider bearing on the rods, the mains are all the same. If you are using the proper rods with the proper crank there should not be a problem. And nope, ACLs should fit and be sized exactly like stock, if not then something is wrong.
Old Mar 25, 2005 | 02:30 PM
  #32
hmm... i donno what to think anymore. All i know is i have eagle rods for a gsr and i order gsr rod bearings from acura.
douglas_be
Feb 23, 2004 09:17 AM
nicklk
Feb 9, 2004 06:41 PM
jeremy.
Sep 23, 2003 05:40 PM
crx1856
Sep 20, 2003 01:15 AM
