Bad ? Eagle rods...
Old Mar 23, 2005 | 09:12 AM
adictionbass's Avatar
Default Bad ? Eagle rods...
Where is the homepage for eagle rods? Does a different manufacturer make them?
Rebuilding my bottom end and ive gotten 3 people telling me that honda rod bearing will work on eagle rods. And ive got 3 people telling me honda bearings wont work.
The code on the rod is CRS 5430 C if that makes a difference...
Old Mar 23, 2005 | 09:18 AM
tthame1's Avatar
Default Re: Bad ? Eagle rods... (adictionbass)
Honda bearings will work on Eagle rods. I know because im using them and so are about 5 others i know.
turboEGhatch's Avatar
http://www.eaglerod.com
Correct, Honda bearings work with Eagle rods. Exospeed assembles motors with Honda bearings on Eagle rods, and I run Honda bearings on my Eagle rods.
Old Mar 23, 2005 | 09:22 AM
ExospeedAMcrx's Avatar
what Da? EAgle rods WILL work with Honda Bearings. I dont know where they got that idea.
Old Mar 23, 2005 | 09:23 AM
Default Re: Bad ? Eagle rods... (turboEGhatch)
ok cool. Honda bearings it is.
All the bearing are the same for all B motors right? I get more then half off at honda so i was going to order all the bearings for a civic SI or a del sol dohc vtec.
Im running a 98 gsr motor.
Old Mar 23, 2005 | 09:53 AM
Better question... I used the Honda code way to figure out my honda main bearings. (need 4 browns and 1 black) But how do i get the bearing code with the honda crank and the eagle rods?
Old Mar 23, 2005 | 09:56 AM
Muckman's Avatar
Moderator in Chief
You have to plastigauge the new clearances. You probably will need different sizes (colors).
Old Mar 23, 2005 | 10:06 AM
Default Re: Bad ? Eagle rods... (Muckman)
how bad of an ida would it be to do the honda main bearings and ACL race rod bearings?
Old Mar 23, 2005 | 10:32 AM
jDMJeRk's Avatar
the race bearnings dont last as long.... I wouldnt get them if your daily driving your car
Old Mar 23, 2005 | 10:36 AM
Default Re: (jDMJeRk)
really? Damn it, i want honda bearings but now i wont be able to get them till next week.. So much for getting it running this weekend.
Thanks for your help guys.
Old Mar 23, 2005 | 11:12 AM
jDMJeRk's Avatar
Default Re: (adictionbass)
just use regular acl bearnings, they make two kinds
Old Mar 23, 2005 | 11:28 AM
vaporboy12's Avatar
just try honda green if you didnt have a problem with you last set of rods and crank
700 posts lucky!!!!
Old Mar 23, 2005 | 11:49 AM
Default Re: (vaporboy12)
well, it had acl bearing in it, dont know what kind, but they were pretty scared up... So regular acl should be good...?
Old Mar 23, 2005 | 01:32 PM
bump... Motor is probably going to see ~5000 miles a year and 450 hp...
Old Mar 23, 2005 | 09:22 PM
Jaker's Avatar
Eagle rods are sized like a Honda number 3 rod.
Old Mar 23, 2005 | 11:20 PM
Default Re: (Jaker)
can you elaborate on honda number 3 rod?
Old Mar 24, 2005 | 12:35 AM
hondaapi's Avatar
Thats the same what Eagle told me when I called them about that issue last week.
Kevin
Old Mar 24, 2005 | 04:51 AM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">can you elaborate on honda number 3 rod?</TD></TR></TABLE>
When picking rod bearings for a Honda, you use a code stamped on the rod and the crankshaft. The code on the rod is a number (1,2,3,4) and the code on the crank is a letter (a,b,c,d,e). These codes represent the dimensions of the rod bore and the journal diameter. By putting these codes together (A1, B3, D2, etc...) you get a color from the factory service manual that represents the correct (possibly) thickness of bearing to order from Honda.
Old Mar 24, 2005 | 05:55 AM
1Bar GSR's Avatar
Default Re: (Jaker)
Just get all acl bearings I have them and I love them!
Old Mar 24, 2005 | 09:10 AM
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">
When picking rod bearings for a Honda, you use a code stamped on the rod and the crankshaft. The code on the rod is a number (1,2,3,4) and the code on the crank is a letter (a,b,c,d,e). These codes represent the dimensions of the rod bore and the journal diameter. By putting these codes together (A1, B3, D2, etc...) you get a color from the factory service manual that represents the correct (possibly) thickness of bearing to order from Honda.</TD></TR></TABLE>
awesome dude, thats just the info i needed thats how i 'measured' for the mains but the aftermarket rods obviously dont have the code stamped on them
Old Mar 24, 2005 | 09:51 AM
nfn15037's Avatar
Honestly, Eagle rods have pretty loose tolerances. A manley or Pauter rod I could see being a #3 but Eagle rods are all over the place from what I have seen. Plastigauge them to be sure!!!
Old Mar 24, 2005 | 11:39 AM
Default Re: (nfn15037)
Anyone else have any info on this?
Ive never plastigauged, but i get theo hole concept of putthing the plastigage in then torqueing the rods on, the measuring the plastigauge. When you get the measurement, how do you know what color honda bearing to use?
Old Mar 24, 2005 | 12:14 PM
Jaker's Avatar
I have not heard of, nor experienced Eagle rods that were "out of tolerance". However, if you plastigauge, and find the clearances a little too loose or tight, each color of Honda bearing changes by .0002". Therefore, if you have a plastigauge measurement of .0017" and you're after .0015", change from a yellow bearing (for example) to a green one. Also, if you're out by .0001" (you measured .0018" and you're after .0017") you could use 1 half of a yellow and one half of a green to achieve your desired clearance.
These are only examples, and not intended to be specific recomendations for color selections. YMMV.
Old Mar 24, 2005 | 12:28 PM
Default Re: (Jaker)
so the honda green bearing have a clearance of .0015? And they change +/-.0002. Just making sure i got it right
Old Mar 24, 2005 | 12:55 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">so the honda green bearing have a clearance of .0015? And they change +/-.0002. Just making sure i got it right </TD></TR></TABLE>
It all depends on how the end of the rod is sized and to some degree if any material has been removed from the crank journal.
