Bad Alternator?
Old Jul 10, 2014 | 08:07 AM
CDecker0218's Avatar
Default Bad Alternator?
Recently brought my turbo integra down to Chris Miller to get tuned. While on the dyno, the battery light would keep turning on after it hit about 8500rpm or so. The alternator was reading 18 volts. We took off the alt belt and If I remember correctly chris unconncted something and said when he did that it was at 11 volts. He also said to check ground wires going to the alternator. I actually brought a brand new altnerator back in october of last year but it was from advanced auto and not OEM. As I check everything over is there anything else I should look into? Im going back down in a few weeks but any suggestions would be greatful. Thanks guys!
Old Jul 10, 2014 | 08:16 AM
Muckman's Avatar
Moderator in Chief
Default Re: Bad Alternator?
He probably enabled the ELD. I had an alternator die on the dyno too from the high rpm. Those reman's suck. Data log the battery voltage at high rpm. It should stay around 14 volts.
Old Jul 10, 2014 | 01:47 PM
Aradin's Avatar
Premium Member
Interesting. I've been having a similar issue for a couple of years except with used OEM alternators. Don't see the point in buying a new one because I keep killing the used ones in as little as 6 months. Pretty much all of them are low miles, good condition from a junkyard. My voltage doesn't go near that high though. Maxes out at about 15.5v rarely. Done a lot of troubleshooting and still haven't been able to figure it out.
p3p69
Sep 12, 2013 08:15 AM
90HondaDA
Oct 6, 2010 01:59 PM
carlthecrx
Dec 19, 2007 03:36 PM
dohc_profile
May 31, 2006 06:45 PM
pstutz
Apr 26, 2003 12:05 PM
