backfire... normal?
Old Mar 2, 2005 | 07:20 AM
budget's Avatar
Default backfire... normal?
when it idling i can hear it make pop pop sound consistantly. is this normal? and whenever im at high rpms and shifting to the next gear it makes a loud backfire noise, is that pretty normal? and yes the car is tuned
set up-
3in open downpipe
Old Mar 2, 2005 | 07:23 AM
Evanmb44's Avatar
Default Re: backfire... normal? (ratboy)
i think you may want to check out the popping noise at idle
its pretty normal for it to do it when you are shifting like that, but not at idle
Old Mar 2, 2005 | 07:30 AM
budget's Avatar
Default Re: backfire... normal? (Evanmb44)
at idle its not nearly as loud as when im at high rpms shifting, at idle its only small, quiet, puffing noises
Old Mar 2, 2005 | 07:37 AM
Bailhatch's Avatar
ya my untuned booberdata setup did that. little puffs at idle. Always wondered why but never cared enough to try and fix it.
Old Mar 2, 2005 | 07:41 AM
Evanmb44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ratboy &raquo;</TD></TR><TR><TD CLASS="quote">
at idle its not nearly as loud as when im at high rpms shifting, at idle its only small, quiet, puffing noises</TD></TR></TABLE>
well, the small puffs might be nothing to worry about.
can you hear them while you are sitting in the car, or from only outside the car?
Old Mar 2, 2005 | 07:51 AM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">
can you hear them while you are sitting in the car, or from only outside the car?</TD></TR></TABLE>
both... is that bad? what could be the problem?
Old Mar 2, 2005 | 08:32 AM
Evanmb44's Avatar
is it constantly or only sometimes?
Old Mar 2, 2005 | 08:41 AM
MidShipCivic's Avatar
My cars pops like that (not at idle) also, but it isn't a problem with misfiring, its not problem at all.
Old Mar 2, 2005 | 09:28 AM
vaporboy12's Avatar
Default Re: (MidShipCivic)
my car pops at idle i think its cause of my big *** injectors trying to idle the car
Old Mar 2, 2005 | 04:02 PM
budget's Avatar
Default Re: (vaporboy12)
so the backfire at high rpm's is normal right? thanksguys
Old Mar 2, 2005 | 08:36 PM
vaporboy12's Avatar
Default Re: (ratboy)
yes with open downpipe pops at high rpm most likely come out as fire
Old Mar 2, 2005 | 08:59 PM
SHystrdyGSRtdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">yes with open downpipe pops at high rpm most likely come out as fire </TD></TR></TABLE>
i don't know if that's what you consider "normal".. that means there's fuel combusting in or near the turbine?
Old Mar 2, 2005 | 11:38 PM
s2kdre's Avatar
Default Re: (SHystrdyGSRtdy)
backfire is just unburned fuel thats all nothin to worry about.
Old Mar 3, 2005 | 12:06 AM
dustin's Avatar
Sounds like it's just lightly misfiring at idle. Big injectors do wacky things. Might want to check the tuning at idle if it bothers you. Richening up idle a little from 14.7:1 can smooth things out sometimes with big injectors.. like 14:1 or so. (assuming not using closed loop o2).
Old Mar 3, 2005 | 06:50 AM
budget's Avatar
Default Re: backfire... normal? (dustin)
thanks for all the responces
Old Mar 3, 2005 | 06:57 AM
SOHC_MShue's Avatar
mine is like that at idle as well. My idle afr is around 15.1:1
Shidou
Dec 21, 2016 10:39 PM
Tippyman
Aug 7, 2007 07:47 PM
TheNasty0ne
Dec 17, 2005 01:07 PM
Gump
12
Dec 5, 2003 02:11 PM
