Back From the Dyno with the Built B16.........
Old Jul 31, 2004 | 10:14 PM
  #26
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Back From the Dyno with the Built B16......... (Bulldogg83)
Becareful with that timing brian. BTW, save the map, I want to see it.
art
Old Aug 3, 2004 | 08:42 AM
  #27
espanol's Avatar
Default Re: Back From the Dyno with the Built B16......... (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Becareful with that timing brian. BTW, save the map, I want to see it.
art</TD></TR></TABLE>
why?what do you think will happen?
Old Aug 3, 2004 | 08:55 AM
  #28
Drag_On's Avatar
Yeah that timing is nasty for 15 psi. I would check that asap.
The numbers look great. Have you toyed with the idea of ITR cams? With higher compression, larger bore and lower boost levels on the street I could see your mtor benefiting from them with the 1000cc's and a nice tune on it.
Also - it looks like your running an open diff. Wow - quaife that bitch!!!
Nice numbers - watch that timing and check the plugs ASAP.
Old Aug 3, 2004 | 09:27 AM
  #29
slowpokesi's Avatar
Default Re: (Drag_On)
brian your a bastard,
are you still working at the mall lol, because if you are im going to quit my job and come work with you, it must be nice to be able to afford all that ****
goodluck with everything, you should find some slicks for this weekend, and some spare axles just in case.
Old Aug 3, 2004 | 09:48 AM
  #30
turbo*s2k's Avatar
nice #'s!
Old Aug 3, 2004 | 10:20 AM
  #31
White Smoke's Avatar
i my honda
Global Mod
Default Re: Back From the Dyno with the Built B16......... (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">nice #'s! </TD></TR></TABLE>
Glad to see you stuck with the b16 Most would not
Old Aug 3, 2004 | 10:54 AM
  #32
Oyvind Ryeng's Avatar
Wow, that is some good numbers for a 10.5-compression engine on pump gas! I'd guess off-boost response is great with all that compression, maybe similar to a stock B16 off boost? Did you log your intake air temperatures (after the intercooler)? Also, the timing seems a little on the agressive side. I'd hate to see you blow up that fine-*** built machine...
Old Aug 3, 2004 | 02:08 PM
  #33
Bulldogg83's Avatar
Default Re: (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">brian your a bastard,
goodluck with everything, you should find some slicks for this weekend, and some spare axles just in case.</TD></TR></TABLE>
lol...nah not working at the mall anymore....
Checked the plugs and there are no signs of detonation what so ever...doing compression test tomorrow to check everything out. Right now I am toying with the possibility of just keeping it on pump gas for this coming event and than tuning it with race gas for NOPI since I do not have a cage yet nor do I have a scatter shield in case I were to break into the 11's. I'd hate to be kicked off after just one pass.
Thanks for the props on the b16. That is the whole reason why I went with it since not many people do and what not. Just thought that I would be different in my neck of the woods.
Old Aug 3, 2004 | 03:26 PM
  #34
AVATAR's Avatar
Default Re: (Bulldogg83)
GET A COMP. AND LEAKDOWN TEST . . . THEN CHECK YOUR OIL PRESSURE ! ! ! You dont want a blown built engine dude also if the timing is as bad as everyone says, next time you go for the race gas tune have them pull some timing . . . better safe than sorry. Longevity over the possibilty of an empty wallet and headaches
Old Aug 3, 2004 | 03:31 PM
  #35
Bulldogg83's Avatar
Default Re: (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">GET A COMP. AND LEAKDOWN TEST . . . THEN CHECK YOUR OIL PRESSURE ! ! ! You dont want a blown built engine dude also if the timing is as bad as everyone says, next time you go for the race gas tune have them pull some timing . . . better safe than sorry. Longevity over the possibilty of an empty wallet and headaches </TD></TR></TABLE>
*noted*
Old Aug 3, 2004 | 05:28 PM
  #36
si_blues's Avatar
Default Re: Back From the Dyno with the Built B16......... (b20turbojason)
kick *** numbers man!!
Old Aug 3, 2004 | 09:31 PM
  #37
Bulldogg83's Avatar
Default Re: Back From the Dyno with the Built B16......... (si_blues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_blues &raquo;</TD></TR><TR><TD CLASS="quote">kick *** numbers man!!</TD></TR></TABLE>
gracias
Old Aug 3, 2004 | 09:49 PM
  #38
shermanyang's Avatar
very nice...although i would of thought that you would be making a bit more torque since you're at a 84mm bore. none the less, those are GREAT numbers and i would honestly die to have those numbers on my LS once i get it running right.
Old Aug 3, 2004 | 10:35 PM
  #39
JDogg's Avatar
Default Re: Back From the Dyno with the Built B16......... (shermanyang)
im with mase on that one..... the choppyness in the dyno graph may not be just smoothing..... dynojets suck for good resolution in the chart, but i woudl suspect slight detonation.
Old Aug 3, 2004 | 10:37 PM
  #40
Bulldogg83's Avatar
Default Re: Back From the Dyno with the Built B16......... (JDogg)
Thanks for all the positive feedback. Within the next few days I am going to change the timing on the car to something a little more conservative and just have the real fun with it on the track.
Old Aug 4, 2004 | 12:10 AM
  #41
JDogg's Avatar
if the detonation isnt audible, then you shouldnt loose any power by pulling back the timing... hell you might pick some up.
good numbers tho.. anything 350hp+ is a bad *** street car.
Old Aug 4, 2004 | 01:33 AM
  #42
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">if the detonation isnt audible, then you shouldnt loose any power by pulling back the timing... hell you might pick some up.
good numbers tho.. anything 350hp+ is a bad *** street car. </TD></TR></TABLE>
Totally! If you are making the same hp at lower timing why go higher.
Old Aug 4, 2004 | 06:10 AM
  #43
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the props on the b16. That is the whole reason why I went with it since not many people do and what not. Just thought that I would be different in my neck of the woods. </TD></TR></TABLE>
lol, you swear your the best driver around.worry about hitting twelves first.
Totally! If you are making the same hp at lower timing why go higher.</TD></TR></TABLE>
obviously he was making power w/ less timing..it's not like the tuner just picked a number.hmmm, let's see i'll just set the timing at 22 and see what happens.i think the choppyness is bulldogg's distributer going bad, but don't take my word for it, my car only made sub 500 whp on pump gas.
  #44
quikB18B's Avatar
Exactly
Brian im going to try and make it out there on friday
Old Aug 4, 2004 | 06:38 AM
  #45
espanol's Avatar
Default Re: Back From the Dyno with the Built B16......... (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly
Brian im going to try and make it out there on friday </TD></TR></TABLE>
does nobody read my replies.maybe the tuner of the car should chime in.or better yet, maybe you and arturbo should tune bulldogg's car.
btw, i was j/k...bitches
Old Aug 4, 2004 | 09:09 PM
  #46
Bulldogg83's Avatar
Default Re: (espanol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">
obviously he was making power w/ less timing..it's not like the tuner just picked a number.hmmm, let's see i'll just set the timing at 22 and see what happens.i think the choppyness is bulldogg's distributer going bad, but don't take my word for it, my car only made sub 500 whp on pump gas. </TD></TR></TABLE>
I AM the best driver around...
thanks for the support.
Old Aug 4, 2004 | 10:26 PM
  #47
ahobbs's Avatar
HELLO,GOOD MORNIN'
Nice, now that maybe some competiotion with my Bike
Old Aug 5, 2004 | 06:43 AM
  #48
espanol's Avatar
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">Nice, now that maybe some competiotion with my Bike </TD></TR></TABLE>
did you get the training wheels off yet?
Old Aug 5, 2004 | 07:25 AM
  #49
Bulldogg83's Avatar
just let me know when you wanna go.
Old Aug 7, 2004 | 12:03 AM
  #50
Bulldogg83's Avatar
just an update we retuned the car today and did a compression test....Compression was a flat 200 across the board meaning that my compression is more like 10:1.....moved timing back to 19 degrees and make 401whp/267ftlb of torque @ 16lbs on 93 octane....will post the dyno sheet this weekend.
