b20vtec turbo
Old Apr 19, 2011 | 10:28 AM
hybridmiklo's Avatar
Default b20vtec turbo
Whats up guys, i have a few questions. I currently run a single cam turbo setup that has run great!! Im currently running a t3 super 60 on it right now.
Now I have a b20vtec in which I plan on turboing. Its with a pr3 head. I currently have 440cc injectors on my single cam. What size injectors should I run with the b20vtec? I actually plan on running my garret t3 super 60 on it too. I want to hit 260-280hp. And give or take what's the reliable hp numbers on this setup? Its going to be stock block with arp headstuds
Old Apr 19, 2011 | 11:17 AM
P-CRIDER's Avatar
Default Re: b20vtec turbo
i would add some arp rod bolts an 550 injectors you will be ok
Old Apr 19, 2011 | 11:22 AM
93lsv_turbo's Avatar
https://honda-tech.com/forums/forced-induction-16/453-whp-300-torque-stock-b20-vtec-2924409/
probably alot less then this but your turboing a car that wasnt designed to be turbo.... so juss make sure you get a damn good tune you should be fine
yungkhmer
Apr 5, 2012 08:45 PM
texaszcrx
Apr 13, 2008 09:31 PM
8Gomer9
May 11, 2007 12:10 PM
96gsrhatch8230
Mar 12, 2007 07:16 PM
lakiaccord
Jan 6, 2004 06:06 AM
