b20v turbo need help
Old Aug 10, 2013 | 10:04 PM
steveDC2's Avatar
Default b20v turbo need help
whats up guys i just honestly need some guidance and what i should do. I have a b20v turbo and want to know whats recommended to get a bigger bang for my buck, its my daily so im just looking for about 400hp lol.. nothing too crazy...
my setup so far:
B20V
Gsr head
port n polish head
supertech springs n retainers
supertech valves exhaust side
blox stage one cams
skunk2 pro series intake manifold
blox 70 mm tb
aem fuel rail
blox fuel pressure regulator
880cc injectors
255 walbro
stock b20 block
gsr transmission
godspeed turbo kit t3/t4
fullrace turbo manifold
tuned on s300
okay thats what im working with. i managed to push 361hp on 12 lbs but i want to get a little more..
on the current to do list:
garret gt35 turbo
tial 44mm wg
1600cc injectors
tuned on boost by gear on e85
skunk2 ultra series street intake manifold
skunk2 70mm tb
aem fpr
lmk if you guys have any suggestions or recommendations, thanks for your time!
Old Aug 10, 2013 | 10:19 PM
Muckman's Avatar
Moderator in Chief
Default Re: b20v turbo need help
Dont you think a GT35 and 1600cc injectors are overkill for 400hp?
If you want a little more than just boost a little more.
I dont even see a need for you to upgrade anything.
Old Aug 10, 2013 | 10:40 PM
steveDC2's Avatar
idk ive been hearing different things, i was told i need bigger injectors to run e85 thus the 1600s.. and i dont really wanna go much higher psi since im on a stock short block, thats why i was told to go with a gt35.. im not too turbo savvy so im just trying to get different perspectives, so pretty much what im trying to know is, is it possible to get 400hp on 12psi?
Old Aug 11, 2013 | 04:10 AM
nsanetrav's Avatar
1600's is a bit high ..friend ran fic 1000's on e85 and didnt have any issues
400 on a stock b20 block ? and are you going with the garret gt35r .63 or .82 ?
Old Aug 11, 2013 | 07:06 AM
crvtectim's Avatar
You're already pushing it at 361whp on stock, cast pistons. For a DD, I'd dial it back some unless engine longevity is not a concern to you.
Old Aug 11, 2013 | 07:29 AM
nealnanoHX's Avatar
Go with a Garrett T3T4 60 trim .63 AR and some ID 1000cc injectors and a retune with more boost. You will get 400whp on 91-93 octane no problem as long as your tune is good and your motor can take it.
Old Aug 11, 2013 | 09:20 AM
Muckman's Avatar
Moderator in Chief
You'd be fine with 1000ccs on E85 with room to spare.
You are under the false pretense that low boost equals safety. It doesn't matter if you make 400hp with 12psi or 20psi, its not any safer.
As crvtectim said - you are already pushing the limits of a stock b20. Dont push your luck any further until you are ready to build it up.
Old Aug 15, 2013 | 03:53 AM
steveDC2's Avatar
Honestly I really appreciate all of your feedback, good to have experienced people give me advice! And muckman I know you're right, I was under that pretense but after seeing what happened to your motor at 5 psi I now understand what you mean, I'm really sorry what happened to your motor btw :/ On another note imma just take all of your advice and start building a gsr block, can you guys give me some tips on what parts I should be purchasing as far as the pistons and rods?
Old Aug 15, 2013 | 04:59 AM
nealnanoHX's Avatar
If you are interested I have a bare B18B1 block and matching crank I will sell. It is screaming for a build.
AdrianArteaga98
Jul 26, 2017 06:26 AM
98couperc4
Apr 19, 2010 05:39 AM
cherryhatch00
Jan 9, 2007 05:33 PM
tEgGsR95
Jul 2, 2004 09:10 PM
Miz101
Jun 26, 2003 10:02 AM
